Multiple Trouble Codes
Old Jan 30, 2023 | 01:31 PM
BigRiig's Avatar
BigRiig
No corrosion and the terminals are all clean and tight. I should do a temperature check again when the engine is cold. When I checked last time, I had been driving so it could have just been heat from the motor.
Old Feb 1, 2023 | 01:44 PM
BigRiig's Avatar
BigRiig
UPDATE: I just replaced the GPR, cleaned all the terminals and tested the voltage. It is showing 10v across all terminals. The check engine light is off for now (probably because I disconnected the batteries) and hopefully will remain off. I still have the P1000 code but that typically happens after I disconnect the batteries. That should go away by itself. Thanks for all the help and I will update if the codes come back.
herschelclinger
Sep 22, 2022 12:34 AM
KillyMcGee
Feb 1, 2019 07:12 PM
Ricson
Oct 17, 2011 08:22 PM
ramsay
Oct 3, 2010 04:37 PM
lsramek1
Sep 3, 2009 02:22 PM
