Door Hinge Replacement Advice? Tips?
Old Jan 21, 2023 | 12:45 PM
5851a's Avatar
5851a
I've used an LTD spring before.
Old Jan 18, 2024 | 07:35 PM
EBaade's Avatar
EBaade
Trailering
Any alignment advice?
My son and I are trying to align the passenger door as it wouldnt close completely without having to slam it, but it would latch. Thought this was a sag issue. Trying to loosen bolts on the body with the door open adjust then tighten to check, then loosen and so on and so on. Is there a better way? We’re using a floor jack and wood to hold the door in place but trying to loosen adjust, and tighten the bolts just made it worse. Thanks for any advice.
1978 f150 Ranger
Old Jan 19, 2024 | 04:16 PM
scottscott's Avatar
scottscott
Make sure your striker is in good condition. There is a plastic sleeve on the striker that falls apart over time. Once that sleeve is gone, the door is hard to close, & rattles while driving. I got a replacement striker from the local auto parts store "Help" rack.
Flyboy1100
Aug 12, 2020 04:25 PM
big red c222
Apr 19, 2009 08:24 PM
jon_boy
Aug 20, 2004 11:39 AM
taxidriver
Paint & Bodywork
May 14, 2004 12:00 PM
boulderdentist
Paint & Bodywork
Jan 19, 2004 08:05 PM
