NP435 Shifter Removal
Old Jan 17, 2023 | 09:52 PM
canderson1015's Avatar
canderson1015
4wd Low
I’m trying to removed the shifter from my np435 to pull the trans out. There is a little cap on the shifter that is keeping it from popping out whenever I turn the little ring to release it. Any ideas? Couldn’t find anything anywhere on how to take this cap off
Old Jan 17, 2023 | 10:20 PM
Red Mercury's Avatar
Red Mercury
That's not a NP435. It's a Borg-Warner T-18 and the cap simply threads off of the top of the transmission, then the stick just lifts out.
Old Jan 17, 2023 | 10:24 PM
Christmas's Avatar
Christmas
Big Channel locks will remove the cap. After that you need to push down on the ball and turn it. That part is a bitch.
Old Jan 17, 2023 | 10:34 PM
Red Mercury
NP435 Gear Shifter Removal - YouTube
Yes, for a NP435. Not for a T-18.
Old Jan 17, 2023 | 10:54 PM
Christmas's Avatar
Christmas
Your right. I wasn't paying attention.
Old Jan 17, 2023 | 11:02 PM
canderson1015
4wd Low
Gotcha I thought it was the np435 cause I was able to put that inner ring down and spin it. I’ll have to try it again tomorrow
Old Jan 24, 2023 | 11:18 PM
JEFFFAFA's Avatar
JEFFFAFA
I'm late to the party here but just in case you haven't done it yet, make sure the trans is in neutral when you remove the shift lever.
Old Jan 25, 2023 | 02:43 AM
Ken Blythen's Avatar
Ken Blythen
And also that the small (1/4") pin that goes sideways into the shifter ball, doesn't drop into the trans as you lift the shifter out. If it does, drain the oil & you should be able to retrieve it through the PTO port.
ericford1984
44
Apr 7, 2012 05:29 AM
F250FarmBoy
Sep 13, 2008 11:05 PM
Mercury Bluz
Jul 29, 2008 08:21 PM
desperado_18_2000
Sep 4, 2006 09:53 PM
pcman
Nov 29, 2002 12:06 PM
