Sponsored by: Real Truck
Please help 2007 f650
Old Jan 15, 2023 | 02:54 PM
RV_Tech's Avatar
RV_Tech
If I am following what I find on the Internet, if you unplug the fuel regulator the pump should be putting out full pressure. You may well be correct about needing a new CP3, but I would not have expected it to fail completely all at once.
Old Jan 15, 2023 | 03:04 PM
Mikefish1's Avatar
Mikefish1
4wd Low
Thank you for your reply, I did unplug the fuel pressure regulator and it gets absolutely no fuel regardless I'm wondering if the CP3 was going bad on the previous owner and finally died on them, I am looking into finding one, I also have a couple of Duramax CP3s that I'm reading are pretty much the same except for the fuel lines need to possibly be moved or bent a different direction but the fuel pressure regulator might cause an issue
Old Jan 15, 2023 | 03:11 PM
RV_Tech's Avatar
RV_Tech
Given that you tried unplugging the regulator, you know as much about your engine (or more) than I do and I do think replacing the CP3 is a logical next step. It would be nice if you didn't have to screw around with moving the lines.
I will sign off at this point as I am out of ideas. I wish you luck,
Steve
Old Jan 15, 2023 | 03:15 PM
Mikefish1's Avatar
Mikefish1
4wd Low
Thank you Steve I greatly appreciate all your help I'm trying to track down a known good used CP3 from a Cummins I could just put in so I don't have to try to move anything, I will post an update thank you so much I appreciate all your time and input it was very helpful
Mikefish1
Large Truck
Jan 15, 2023 07:37 PM
jetskipilot36
17
Feb 18, 2017 10:18 PM
08F150White
2004 - 2008 F150
Jul 20, 2016 06:59 PM
1BadHabit
Jan 31, 2012 08:28 PM
hedhntr
1983 - 2012 Ranger & B-Series
13
Nov 9, 2008 10:53 PM
