Sponsored by: Real Truck
2011 Sterling e-locker in 2004
Old Jan 6, 2023 | 09:18 PM
johngeorge's Avatar
johngeorge
I have a 2004 F350 SRW with a 3.73LS rear. Will the rear electric locking differential from a 2012 bolt right in on my 2004 and allow me to use my 2004 ring & pinion and axle shafts? TIA
Old Jan 7, 2023 | 07:44 AM
00t444e's Avatar
00t444e
Yes, all Ford 10.25/10.5 carriers are interchangeable.
Old Jan 7, 2023 | 07:53 AM
bajaphile's Avatar
bajaphile
Yep, I've got one in my 2001, works great.
Old Jan 14, 2023 | 08:14 AM
Ford OCD's Avatar
Ford OCD
5th Gear
I want to make this same swap in my open-diff 1995 E350. Anybody have the part number handy? Any tips or tricks from the experts? Any reasonable source for used parts?
Old Jan 14, 2023 | 08:46 AM
00t444e's Avatar
00t444e
Does it have a Ford 10.25 axle? I thought most of the E350s had a Dana axle in the rear.
Old Jan 14, 2023 | 08:51 AM
ifrythings's Avatar
ifrythings
Here’s the part numbers, you need both parts to make it work.
Old Jan 14, 2023 | 09:02 AM
SuperDutyScaler's Avatar
SuperDutyScaler
https://www.tascaparts.com/oem-parts...mbly-bc3z4026b
Old Jan 14, 2023 | 09:34 AM
Ford OCD's Avatar
Ford OCD
5th Gear
it is a 10.25 inch
Rear axle code 39 Ford 6250 3.55
Old Jan 14, 2023 | 09:36 AM
Ford OCD's Avatar
Ford OCD
5th Gear
Sure does. Rear axle code 39 Ford 6250 3.55
Old Jan 14, 2023 | 09:45 AM
Ford OCD's Avatar
Ford OCD
5th Gear
Over on the Pirate forum there is a long thread where they discuss that this rear is not designed to take 12v continuously. Apparently it is 12v for 30 seconds then it drops to 5-6v. Any thoughts on that theory?
https://www.pirate4x4.com/threads/st...2548729/page-7
EDIT: Reading through the entire thread, they seem to conclude that 12v constant won't cause a problem...
Here is a youtube video of someone doing this exact swap:
Old Jan 14, 2023 | 09:57 AM
Conanski's Avatar
Conanski
it is a 10.25 inch Rear axle code 39 Ford 6250 3.55
Unless that is a cab n chassis with a box/RV/utility bed on the back it has a Dana60 under it, Ford never put the 10.25 under any of the complete cargo/passenger vans they produced.
Old Jan 14, 2023 | 02:21 PM
00t444e's Avatar
00t444e
I would go with a Detroit Truetrac instead, cheaper, more reliable, and you will get far more use out of it.
Old Jan 15, 2023 | 06:27 PM
Ford OCD's Avatar
Ford OCD
5th Gear
Thank you for all your suggestions and comments.
Cowboy Brett
Jun 2, 2004 08:38 PM
chuiee
2004 - 2008 F150
Nov 29, 2003 02:32 PM
