: 2008 F150 XLT 5.4L will not start. It does crack over.
Help Please! Not sure what to do next. This is a list of things I already checked.
1. Replaced fuse #9 for fuel pump.
2. Checked fuse #9 with check light, power to both sides is good
3. No check engine light
4. Battery is 1.5 years old. Just in case I charged for 1 hr.
5. Replaced fuel filter. Possible clog in fuel line.
6. Detached fuel line at fuel filter, turned key on and fuel came out of line. Seems like fuel pump is working.
7. Every time I can hear the fuel pump prim when I turn the key.
8. Relay#1 starter solenoid, I swapped with relay #2 and also replaced
9. FPDM replacement, I removed and it looked to be good.
10. Light checked all fuses, only fuse #5, fuse#35, and Fuse#36 did not have power. These fuses don’t seem to have anything to do with starting or fuel to the engine.
11. inertia switch check is good
put the key in the ignition and turn to "on", not start.... the THEFT light will come on for 3 seconds, AND the fuel pump will run for 3 seconds........... does the THEFT light go out after 3 seconds ? If so, then the key is recognized by the PATS receiver and being proper.... if the light stays on, you have a KEY or ELECT problem, not gas.
unleashd
36
11-15-2018 08:53 PM
9902ford
1997 - 2003 F150
16
06-04-2013 06:20 PM
damnedin82
39
05-02-2008 10:27 AM
