fuel pump wont run. Help
Old Nov 8, 2008 | 09:46 PM
hedhntr's Avatar
hedhntr
unless im wrong I have never seen an electric fuel pump not come on with the key on but will when your cranking the motor. I replaced the fuel pump and Im getting the same thing it will start but some times if you tap the gas it will die and other times it will run. I pulled the fuel filter and turned on the key but I dont get any gas but when I crank the motor gas will come out. 1992 b-2600. Any Ideas
Old Nov 9, 2008 | 03:23 AM
michigan66's Avatar
michigan66
When you turn the ignition to "ON" but not to "START," you should hear the fuel pump run for a few seconds. Do you hear the pump run? If not, you may need to replace the fuel pump relay. It is located beneath the engine compartment fuse box.
If the pump runs, check for fuel pressure. There is a Schrader type valve on the fuel rail. Also, pull the vacuum line off the fuel pressure regulator. If there is gas in the line, the regulator is bad.
Old Nov 9, 2008 | 11:50 AM
hedhntr's Avatar
hedhntr
I cant hear the pump but it it will fire right up and run till its hot or sometimes it wont run at all. Do you have a picture of the relay. No gas in the regulator
Old Nov 9, 2008 | 03:08 PM
87 XLT's Avatar
87 XLT
Something is whacked with the PCM/ECA. Take a couple of minutes to pull the codes & see if that gives you any clues such as a code 511 ECA memory failure or maybe a 513 ECA voltage failure..
The ECA/computer is supposed to ground the pump relay & run the pump for 2 seconds when the key is turned one click. When the engine is running & the ECA sees ignition pulses it holds the ground to the relay to keep the pump running.
BTW do all the dash lights & the check engine light come on when you turn the key one click?
Old Nov 9, 2008 | 04:35 PM
hedhntr's Avatar
hedhntr
Is there a way to pull the codes or only with a code reader? All lights come on with a single turn. I pulled off the fuel pump relay it is a pigtail type 4 wires is there a way to check this?
Old Nov 9, 2008 | 04:53 PM
87 XLT's Avatar
87 XLT
Scanners are so cheap that I bought one many moons ago.
There used to be a link in the "read first tech info" for pulling codes with a paper clip, but I see it's gone.
Do a google search "pulling EEC-4 codes" & you should find something.
Edit
I'm sure your pump relay is good or the pump would'nt run at all
But if you want to test it, just connect the coil side lugs to your battery & it should click.
Old Nov 9, 2008 | 05:28 PM
hedhntr's Avatar
hedhntr
thanks I will give that a shot. I called the auto parts store and they said the only way to scan that is with the scanner that only machines have
Old Nov 9, 2008 | 05:41 PM
hedhntr's Avatar
hedhntr
I found a pretty good write up on it but I dont know where to make all the conections
Old Nov 9, 2008 | 05:46 PM
87 XLT's Avatar
87 XLT
If you had a 96 or newer the parts store would be correct & you'd need an obd-2 scanner.
Heres what you need to find uder the hood to pull the codes.
Super High Output
Good luck with it.
Old Nov 9, 2008 | 06:16 PM
hedhntr's Avatar
hedhntr
Do you know if that will be hooked up to something or just laying around in there
Old Nov 9, 2008 | 06:38 PM
87 XLT's Avatar
87 XLT
It took me awhile to find the miserable thing on my 87 Ranger as it was hanging at the end of it's wires near the heater blower motor.
Much better setup on my 95 Taurus which had it clipped to the passenger side firewall.
I have no idea where it would be on your 92.
Old Nov 9, 2008 | 07:18 PM
hedhntr's Avatar
hedhntr
I did find when you test the ful pump preasure that you have to jumper 2 wires with the key on to start your pump so it sounds to me that just turning on the key dosent start your fuel pump. If thats corect it would be the first electric fuel pump I have heard of that dosent come on when the key is turned. I did find a few plugs not conected just hanging there with no place to go but none of them look like the pics in the diagram, Maybe start back on the ignition. Do you have any other thoughts. Thanks
Old Nov 9, 2008 | 09:25 PM
87 XLT's Avatar
87 XLT
Well, i've always thought that the Mazda & Ranger pickups were twins. Maybe thats not the case??
If you have the Haynes or Chiltons manual for your truck, it should tell you how to pull the codes. It should also have a pump circuit wiring diagram.
Old Nov 9, 2008 | 10:53 PM
hedhntr's Avatar
hedhntr
I always thought there were twins as well. It has a wiring diagram but its hard as hell to understand. Thanks for all your help it was huge. If I figure anything out I will post.
DougieWebb
33
Mar 25, 2013 08:35 AM
19fifty4
Feb 8, 2012 09:48 PM
Peter94
Oct 19, 2006 10:55 PM
therealulysses
Mar 9, 2006 11:53 AM
