Which coolant
Old Jan 11, 2023 | 01:09 PM
kevin.ford-trucks's Avatar
kevin.ford-trucks
Which coolant
In July of 2021 I drained, then filled with distilled water and drained several times before filling with Prestone 10 year/300K coolant. There's some debate about using orange vs green vs yellow vs gold.
Am I ok as is? What should I use on the next round?
Old Jan 11, 2023 | 01:19 PM
ptolalibertad's Avatar
ptolalibertad
250,000 on mine..barely 3000 miles last year..just did the same as you..i just put the regular green
Old Jan 11, 2023 | 04:44 PM
01__Excursion's Avatar
01__Excursion
Here is what Ford published.
File Type: pdf
Old Jan 11, 2023 | 06:45 PM
kevin.ford-trucks
I guess I am using the green coolant in the yellow prestone container!
Old Jan 11, 2023 | 06:47 PM
kevin.ford-trucks
What's the service schedule for each?
Old Jan 11, 2023 | 08:01 PM
Theboneskes's Avatar
Theboneskes
Im assuming your talking about the gasoline versions of the Excursions, and not the diesels...
Old Jan 11, 2023 | 08:05 PM
wpnaes's Avatar
wpnaes
I’ve had good luck with G05.
Old Jan 11, 2023 | 10:16 PM
kevin.ford-trucks
Yes, the V10
Old Jan 11, 2023 | 10:19 PM
kevin.ford-trucks
I've heard similar, but looking at that picture it shows 5y/150K vs Prestone's 10y/300K claim.
I did use the G05 in my 2000 JD tractor.
jed1894
29
Oct 15, 2022 01:25 PM
Resendiz
Nov 30, 2017 02:03 PM
Medic 66
20
Jan 17, 2006 01:29 PM
fhartell
Jan 1, 2004 06:44 AM
02superstroker
Apr 12, 2003 06:51 AM
