Coolant ?
Old Dec 30, 2003 | 03:19 PM
fhartell's Avatar
fhartell
Coolant ?
I've seen post's concerning the adding of the DCA4 Coolant Addative. Just wondering if theres an antifreeze w/ this already in it & would you still need to add the DCA4 when the levels get low? Thanks
Old Dec 30, 2003 | 07:23 PM
JMorton's Avatar
JMorton
With green coolant you always have to check and add dca to the coolant. Otherwise, cavitation will harm the cylinder walls. Ford recommends adding it every 15000 miles.
Old Dec 31, 2003 | 03:09 PM
fhartell's Avatar
fhartell
How bout the orange coolants? Do you need to add the DCA4? If not who is the company that supplies the orange & how can you get a complete flush of the green coolant? Thanks
Old Jan 1, 2004 | 06:44 AM
Oneof6's Avatar
Oneof6
Fhartell, don't use the "Orange" coolant in your PSD. it is not compatible with some of the o-rings and pump parts. Instead there is good news. I have read that recently Ford issued a new TSB on coolant changes in late model PSD's. You can now change your Green coolant to the Gold extended life coolant. Gold NOT Orange. With the Gold coolant no additive is required, good for 100K. If you do this change over do a complete flush with distilled water, I would do it a couple of times, to get all the Green out. I get my MotoCraft Gold coolant online for a little over 9 bucks per gallon. If it were me, rather than be concerned about additive levels I would flush then fill with the Gold coolant.
Regards, and a happy new year.
Regards
slowjack
Apr 29, 2015 06:40 AM
huntke
6.4L Power Stroke Diesel
Aug 27, 2014 06:17 AM
PSDx3
Jan 30, 2010 08:49 PM
IDIDieselJohn
Dec 17, 2009 11:47 PM
Emil
Dec 15, 2003 08:16 PM
