coolant
Old Apr 6, 2003 | 06:20 PM
02superstroker's Avatar
02superstroker
coolant
at how many miles should the factory coolant be replaced? also which coolant are most of yall running? thanks
Old Apr 6, 2003 | 11:51 PM
The Diesel Dude's Avatar
The Diesel Dude
coolant
Is the coolant yellow or green?
Old Apr 7, 2003 | 12:25 AM
JoeBoost's Avatar
JoeBoost
coolant
I was also wondering this as well. I have the yellow coolant on my 2002 Excursion PSD , and was wondering when it should be changed , as well as what i should add to it when it gets low. Should I only use the ford stuff , or can water be added safely ???
Old Apr 7, 2003 | 07:45 AM
powerstroker250's Avatar
powerstroker250
coolant
Green coolant at 45k then every 30k. Yellow or gold coolant every 100k.
Les
Old Apr 7, 2003 | 05:20 PM
02superstroker
coolant
neither....it is the stuff from the factory, kinda a dirty water look... but it isnt water
Old Apr 8, 2003 | 12:19 AM
SouthernDually's Avatar
SouthernDually
Wink coolant
I was talking to my local dealer the other day about hose clamps and such. He did state that If you had the gold or yellow coolant that you should never use the green and visa versa. It has to do with the material in the system. One will mess with the other. Also it seems it has somthing to do with where they are manufactured. I wasn't able to get much more but it is extreamly important which your truck is/has or is recomended. I would take it to my local dealer and ask. He can find out with the vin through the Ford dealer or maintence records.
Just trying to help.
God Bless our Troops.
Old Apr 8, 2003 | 12:22 AM
SouthernDually
Thumbs up coolant
Powerstroker I really liked that guage you had. checked out the site and havn't seen one like that before. You said that it is a Westech gage ? What is the diameter of the gage? Could it be mounted in a pillar type mount or is it to large.
Nice Truck
God Bless Our Troops
Old Apr 8, 2003 | 07:48 AM
powerstroker250
coolant
It is a 3" gauge, don't know if it will fit in a pillar pod. I didn't want pillar gauges thats why I went with the bigger 3" gauge. They do make a combo boost/egt gauge that will fit in the pillar pods. Order thier catalog, they have alot of gauges not shown on thier website.
Les
Old Apr 9, 2003 | 11:53 AM
deep6's Avatar
deep6
coolant
Powerstroker....I noticed your rig is a 4WD, but where did you move the 4WD switch to? Did your year have it in a different place? I really like that guage and the location but my 2002 has the 4wd switch right there.......
thanks
Also.,....I have the same question as Joe Boost...my yellow coolant level is just below the line.....what do I add?
Old Apr 9, 2003 | 09:18 PM
02superstroker
coolant
perhaps he has the manual 4x4 shifter.. some people do still go that route... me, and i love knowing it actually goes into 4wd!
Old Apr 10, 2003 | 07:38 AM
powerstroker250
coolant
Yep, 4x4 manual shifter.
Les
Old Apr 11, 2003 | 10:56 PM
SouthernDually
Thumbs up coolant
Just thought that I would let you know that I decided on the pod type guages that mount around the steering column. I found a nice set up using the 2 1/16 guages that set on both sides. I kind of liked this set up. It keeps the guages in one centeral area. I also decided on the white faced guages, it makes them a little more prevelent (sp) and easier to see. Once I get them in and everything working properly I'll get some pic's posted.
Thanks again for the info.
God Bless our Troops:
Old Apr 12, 2003 | 06:51 AM
powerstroker250
coolant
It's personal preference, glad you found what you like.
Les
