Need help
Old Jan 4, 2023 | 10:02 AM
Poppydawg's Avatar
Poppydawg
4th Gear
Need help
Have 2017 F350 and pull a 43' fifth wheel. Added Ford's trailer camera and TPMS to my rig. Works great, but have a recent problem that I am having trouble finding a solution to. My truck side plug for the camera and tpms cable got hung on my tail gate and the cable was separated from the male plug. I am trying to find a wiring diagram for the cable, but not having any luck. The local Ford dealership is trying to help but no results. I hope you or someone on thread can help me find a diagram or at least somewhere to get another cable. Thanks in advance.
Old Jan 4, 2023 | 11:40 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
How does the other end of the cable connect to the trailer?
Another male plug, or does it hard wire to the accessories?
Old Jan 4, 2023 | 11:48 AM
inane2's Avatar
inane2
This is from Nichols :
https://nicholsmanufacturingandweldi....com/resources
Poppydawg's Avatar
Poppydawg
4th Gear
It attaches with a smaller male plug to another cable going to the camera, and a second male plug to the tpms monitor box.
Old Jan 4, 2023 | 11:58 AM
Poppydawg's Avatar
Poppydawg
4th Gear
Thank you inane2, this is exactly what I need to get the camper camera up and going again.
Old Jan 4, 2023 | 12:00 PM
Poppydawg's Avatar
Poppydawg
4th Gear
Old Jan 4, 2023 | 06:54 PM
inane2's Avatar
inane2
Glad to help.
I just recently installed the same camera / TPMS system onto my camper and it's priceless. I can't recommend it enough. Used my Ford Pass points to cover most of the purchase from Fairway Ford.
Old Jan 5, 2023 | 09:22 AM
Buckeye-SD's Avatar
Buckeye-SD
Originally Posted by inane2
Glad to help.
Do you have the part number for the kit you ordered?
Old Jan 7, 2023 | 07:14 PM
inane2's Avatar
inane2
Hey Buckeye, after much research, I ordered : LC3Z-1A189-A. This is the complete kit with camera, TPMS sensors and wiring harness (including a connector for the yaw sensor).
https://www.fairwayfordparts.net/oem...era-lc3z1a189a
I'm not using the yaw sensor on my camper, so I just taped up the connector and zip tied it back to the main harness. I can use this auxiliary trailer camera at any speed. Not a bad install but definitely worth it.
Old Jan 8, 2023 | 03:54 PM
Buckeye-SD's Avatar
Buckeye-SD
Thanks for taking the time! I hope it didn't take too long.
NeuralMonk
May 7, 2008 07:47 AM
Chance_Thomas
All Things Towing
Jun 7, 2006 11:08 PM
Cheapevil
Mar 31, 2005 02:26 PM
Austrian F100
May 21, 2004 01:11 PM
