Have 2017 F350 and pull a 43' fifth wheel. Added Ford's trailer camera and TPMS to my rig. Works great, but have a recent problem that I am having trouble finding a solution to. My truck side plug for the camera and tpms cable got hung on my tail gate and the cable was separated from the male plug. I am trying to find a wiring diagram for the cable, but not having any luck. The local Ford dealership is trying to help but no results. I hope you or someone on thread can help me find a diagram or at least somewhere to get another cable. Thanks in advance.
I just recently installed the same camera / TPMS system onto my camper and it's priceless. I can't recommend it enough. Used my Ford Pass points to cover most of the purchase from Fairway Ford.
Do you have the part number for the kit you ordered?
Hey Buckeye, after much research, I ordered : LC3Z-1A189-A. This is the complete kit with camera, TPMS sensors and wiring harness (including a connector for the yaw sensor).
I'm not using the yaw sensor on my camper, so I just taped up the connector and zip tied it back to the main harness. I can use this auxiliary trailer camera at any speed. Not a bad install but definitely worth it.
Thanks for taking the time! I hope it didn't take too long.
