White smoke problem
Old Jan 1, 2023 | 10:00 AM
1984_BullNose's Avatar
1984_BullNose
3rd Gear
White smoke problem
I have a 1984 6.9L idi none turbo
I have had the truck for 6 month now. The pump was turned down when I bought it so I never noticed any smoke except a little when I would get going again from a light. The smoke was white. Me and my buddy wanted to roll some coal so we turned the pump up 2 flats and that’s when we came to notice that it was all white smoke. It runs good haven’t had any problems with rough starts.
I have replaced, lift pump, injectors, injector caps and lines. I also replaced the fuel filter and fuel filter housing.
After replacing the injectors and cleaning up the little leaks I still get white smoke. I get it on start up and when I’m heavy on the peddle. I’ve seen a little bit of black smoke if I sit idling at a light for a minute than take off I’ll get a little puff.
I’m going to get some clear lines today and check for any other possible air intrusion spots. I have had no luck finding what the problem for the smoke is.
Does anyone have any ideas of something I should check or try to fix my problem?
Old Jan 3, 2023 | 01:18 PM
tjc transport's Avatar
tjc transport
i ain't rite
what does the white smoke smell like? oil, fuel, or coolant?
Old Jan 3, 2023 | 08:42 PM
Prototypemech's Avatar
Prototypemech
Have you checked your compression? White smoke may be due to a low cylinder.
Montanagrizzly
Feb 21, 2011 07:18 PM
Talyn
81
Jul 23, 2010 06:07 PM
beersy50
Nov 15, 2009 07:32 PM
unluckylow
33
Jul 17, 2008 09:49 AM
qtrmile
May 19, 2007 08:16 PM
