White Smoke!
Old Feb 20, 2011 | 10:32 PM
Montanagrizzly's Avatar
Montanagrizzly
White Smoke!
Hi everyone.......So heres the scoop on my 89 7.3. I replaced my return lines due to air intrusion. It then started to smoke blueish white smoke when the engine was not under a load. Put the pedal down and it would not smoke! So since I had 120k on my injectors I replaced them with New injectors and also replaced the IP. In doing so I had One inj that was hard to remove. When I got it out It was full of carbon! I cleaned as well as I could! One problem I had though was I couldn't get the Copper washer out (any help with how to do this would be grateful). I got the pump replaced. I got it started up and now no matter where I turn the pump to it will blow Tons of white smoke and It does have a slight antifreeze smell to it but barely! on a cold start it won't blow anything till it starts to warm up the gets to the point you cant see the road behind you! It does idle a little lower then before too! So with all that said How to do I check to find out if its Cavitaion or Head gasket or niether! I have around 220k on the engine and some of those miles were not the best cared for miles! Did my best while in college but when moneys short its short! I have searched and looked at lots of posts but don't seem to get the direct answers that I'm lookin for! Thanks in advance for the help!
Old Feb 21, 2011 | 11:56 AM
Montanagrizzly
Ok so maybe its more of a gray smoke then anything! When I get home tonight ill start it again and see exactly what color and and how it smells again!
Old Feb 21, 2011 | 12:00 PM
ah1988's Avatar
ah1988
you could use a tiny pick for the cooper washer
Old Feb 21, 2011 | 12:04 PM
Phy's Avatar
Phy
You can also use a long 3/8" lag bolt and kind of thread it into the washer to grab it...
Old Feb 21, 2011 | 12:18 PM
Montanagrizzly
I tried a pic to no avail....I think its pretty stuck but I will try the Lag bolt trick! I have one on hand! Great Idea thanks!
Old Feb 21, 2011 | 07:18 PM
Montanagrizzly
OK so I came home and let the truck warm up real good and made quite a smoke screen for the neighbors who were not at all impressed with my smoke signals abilities! lol My nightmare has been confirmed and I have lots of antifreeze coming out the exhaust! So I guess I just need to figure out if its Cavitation or a head gasket! I imagine since there is no oil in the coolant and no coolant in the oil I will need to disassemble and take the heads off! Can anyone let me know if this is the correct thinking! Thanks
7.3 PowerStroke 350
28
Jun 28, 2023 03:05 PM
wdsloot2
Nov 20, 2012 08:03 PM
McQ
15
Jun 17, 2012 08:33 AM
linus72
Apr 16, 2012 07:40 AM
cgaines1975
Oct 6, 2010 04:45 AM
