Need help diagnosing engine noise
Old Jan 25, 2023 | 09:12 PM
tex_ag's Avatar
tex_ag
4wd Low
If this was a noise from the valve train, such as a collapsed lifer or cam phaser, the noise would continue even if the #4 coil is unplugged, right?
Old Jan 26, 2023 | 12:25 PM
Beechkid's Avatar
Beechkid
Well, yes most likely but I have seen where "funnier" things have happened. IMHO, Time to look into the engine.... start with the heads and then which ever is easier, pull the heads or the pan and start looking at the bearings, etc. IMHO I would also check for crank endplay...... that could be a real good indicator of the internal issues.
ghostpow
2015 - 2020 F150
Feb 20, 2021 11:06 AM
cormierjimmy
Sep 30, 2019 04:59 AM
429poweredf350
Apr 17, 2011 08:24 PM
dpc1192
Jan 7, 2009 11:17 PM
