Snake oil?
Old Dec 21, 2022 | 06:55 PM
brokestroke's Avatar
brokestroke
Snake oil?
This part has been on the market for a few years. Nothing but crickets and can't find anyone that has ever tried them. A few threads debating whether or not it would work but that's it. I figure that it's worth discussing since it is a 7.3 "upgrade??" that has no real reviews.
https://shop.fullforcediesel.com/ffd-hpop-rail-system
Old Dec 21, 2022 | 08:30 PM
Tpayne621's Avatar
Tpayne621
Little bit more and you can actually replace the weak hpop that's 20 years old. lol never seen those before.
Old Dec 21, 2022 | 09:29 PM
ESwift's Avatar
ESwift
CNCFAB
Looks like the only review is from Phillip who is likely the same Phillip thats is one of their sales guys
Old Dec 22, 2022 | 06:33 AM
brokestroke
I noticed that as well, and not a very solid review at that. Figured someone would take a chance on them by now and expose if they are worthless or not.
Old Dec 22, 2022 | 06:59 AM
oharal's Avatar
oharal
All it does is reduce the volume inside the cylinder head oil rail? I am not understanding their description.
Old Dec 22, 2022 | 07:17 AM
RacinJasonWV's Avatar
RacinJasonWV
That’s the way I read it too.
The logic doesn’t seem to make sense to me. The injectors will use the same volume regardless. I would think reducing available volume in the rail would cause the pressure to fluctuate more during each injection. It would also reduce the overall flow rate.
I agree, the review sounded bogus. More of a sales pitch than a review.
Old Dec 22, 2022 | 07:24 AM
oharal's Avatar
oharal
The injectors will use the same volume regardless. [...] It would also reduce the overall flow rate.
You had it, but then ya lost it The flow rate is dictated by the injector oil demand and the rest goes over the IPR back to the starting line. I'm definitely voting snake oil.
Old Dec 22, 2022 | 07:34 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Probably anyone who has bought it was too embarrassed to leave a review 😂
Old Dec 22, 2022 | 08:56 AM
brokestroke
If it didn't work it would be more embarrassing for FFD.
Old Dec 22, 2022 | 09:22 AM
Kwikkordead's Avatar
Kwikkordead
It's hard for me to comprehend how reducing the volume available to the injectors was worth this effort. Maybe trying to make the HPOP system act like a dual pump setup, but on a smaller scale?
Old Dec 23, 2022 | 06:03 AM
brokestroke
Something to do with decreasing the volume of the chamber nets less of a psi drop in the system to refill said chamber. Resulting in more sustained psi to the injectors. ????
Old Dec 23, 2022 | 08:11 AM
Kwikkordead
I can see where it would make the HPOP system more responsive to pressure variations.
I'm waiting for someone to come out with a high volume common rail system. Sled pullers would be all over that one.
Old Dec 23, 2022 | 08:16 AM
z31freakify's Avatar
z31freakify
Already on the market for a while
Old Dec 23, 2022 | 08:34 AM
97-psd's Avatar
97-psd
I would think that would make the IPR and ICP work a lot harder on demanding and supplying oil. I get the basic concept but the fluctuations due to the decreased overall volume to the system would probably cause a decreased lifespan of some components.
there is too much snake in that snake oil for me
Old Dec 24, 2022 | 06:42 AM
brokestroke
According to FFD it causes the opposite and is easier on parts because they aren't working as hard. Someone needs to be the snake oil tester, if it works then it's not snake oil.
