Hubs not always locking
Old Dec 10, 2022 | 09:59 PM
jrod270's Avatar
jrod270
4wd Low
Hi,
I have that factory hubs on my 2018 f 250 XL, and I have found that the hubs don't always want to lock via vacuum. I have checked, and both lines seem to have vacuum when I try to activate, and some of the time it works right away and some of the time it doesn't. Is there any maintenance I can do on these? Coming from a Chevy my whole life, I really liked having auto locking hubs.
Old Dec 11, 2022 | 06:09 AM
senix's Avatar
senix
you need to take the 4x4 portion of the hubs apart and clean and grease. Might have a bad seal there,
the ford system is more robust but does have this issue sometimes
Did you put a vacumn guage on the system to try and determine a leak?
At eash hub on the backside there is a hose that runs from each hub. Check those lines for failure/dis-connected first.
Old Dec 11, 2022 | 12:07 PM
bewildered 7.3's Avatar
bewildered 7.3
I'm following this thread. My hubs stopped auto locking last winter, while driving in ice and snow. I grew up with warn hubs, so once I figured out that I was in 2wd, I got out and locked them manually. I enjoyed the convenience of the auto hubs, when they worked properly. So far it hasn't irritated me enough to make it to the top of the **** to do list.
Old Dec 12, 2022 | 04:54 AM
Overkill2's Avatar
Overkill2
What drives me nuts about these hubs is that if you don't turn them a few times every once in awhile, they seize up... I think I've already had one or the other replaced a few times when I had the truck in for warranty work... I want to pull them off in spring, like I've been saying for quite sometime now, to see how they work and re-grease them.
Old Dec 12, 2022 | 06:36 AM
helifixer's Avatar
helifixer
I haven't worked on the newer hubs yet but I did learn on the older superduty hubs not to grease them. I just take them off and pour a tiny amount of gear oil in them. grease gets too thick when cold for the vacuum to operate them.
Old Dec 12, 2022 | 06:58 AM
senix's Avatar
senix
turn them manually once every 30 days and drive 10 miles. That is what I have always done,
If I know it is going to snow or be really really cold, I just manually lock them in before it gets here.
We are over due for some yuk so I don't know, may head south and let the furnace on the house deal with it.
Old Dec 12, 2022 | 07:18 AM
Overkill2's Avatar
Overkill2
Wow... those a two great tips there. Thanks Gentlemen...
Old Dec 12, 2022 | 08:22 AM
KodiakF250's Avatar
KodiakF250
Is there an advantage to manually exercising them by manually locking them versus periodically exercising the auto vacuum lock by shifting into 4wd?
Old Dec 12, 2022 | 08:39 AM
senix's Avatar
senix
Recommend both be exercised if not used.
Practice before you need to perform.
Old Dec 12, 2022 | 12:46 PM
Sport45's Avatar
Sport45
I agree with both of Senix' comments above. I remove, clean & grease the front hub locks once a year. About once a month I'll manually lock the front hubs for a few miles to spin the front diff. Sometimes I'll put it in 4x4 (while stopped) and then drive a few miles with the hubs unlocked. I disconnected and plugged the vacuum feed to the hubs so they only work in manual mode for me. (My 2-low conversion) I wont shift mine into 4x4 while driving unless the hubs have been manually locked. Just dont like the idea of slamming the transfer case or hubs into play with everything spinning except the front driveline.
Old Dec 21, 2022 | 03:44 PM
lupuseven's Avatar
lupuseven
I Wonder if they'll stick being left in manual lock 100% time? I'm going to have to go check them shortly
I run mine locked all the time, I'm 70/30 off/on road so I just leave them locked up all the time, the minute mileage loss is less important as my time and achyness getting in and out of the truck 6 or 7 times in day.
Mainly because I don't trust the vacuum assist and I do use 4wd pretty hard most times. Just randomly checking wires yesterday (mice are an issue here) I found a busted Vacuum line, so my distrust has been validated,
clintbonnie
Offroad & 4x4
Apr 19, 2021 10:41 AM
sanders92
1978 - 1996 Big Bronco
Dec 22, 2009 11:17 AM
brentleedragon
Nov 20, 2008 08:54 PM
Downriver Thunder
Feb 7, 2007 03:27 PM
philn
Nov 5, 2004 08:24 AM
