Yet another no start issue… sorry.
Old Nov 1, 2022 | 01:19 PM
  #31
Nayterobertson's Avatar
Nayterobertson
Trailering
Ok so I took the pump out and put pressure to it and found to it be leaking a good bit around the shaft, enough that oil was blowing by it.
Location air and oil was blowing out.
But now I’m concerned because I don’t see a ball bearing in it at all.
No ball bearing but doesn’t look like it ever had one.
Should I be concerned and digging around looking for a loose ball bearing in my engine?
Thanks for all your help. I ordered a cncfab hpop and all new seals and o-rings to put it back together. I hope this was the culprit and I don’t have a loose bearing inside my motor.
Old Nov 1, 2022 | 01:41 PM
  #32
bismic's Avatar
bismic
Some people remove the ball bearing and tap the opening for threads so that a plug can be screwed in. That never addresses why the BB blew out in the first place though!
I can't really tell from your picture, but it doesn't look like it has a plug in it either.
If you did lose the ball bearing, hopefully it found the oil pan without causing any damage on the way down.
Old Nov 1, 2022 | 03:56 PM
  #33
Nayterobertson
Trailering
Well that’s a scary thought. Should I run a bore scope around in there and look for it?
Old Nov 1, 2022 | 04:22 PM
  #34
bismic's Avatar
bismic
IMO the opportunity has passed.
Old Nov 10, 2022 | 06:50 AM
  #35
Nayterobertson
Trailering
Just a final update guys. I purchased a stage 1 hpop from cnc fab and got it all buttoned up yesterday. So far it’s running great and the no start has gone away. Thank you all for the advice!
Old Nov 10, 2022 | 07:00 AM
  #36
TooManyToys.'s Avatar
TooManyToys.
That's a plug rather than a ball bearing. It was most likely a rebuilt pump.
Ryan f250 4x4
May 6, 2021 11:15 PM
07greygoose
May 2, 2018 09:37 PM
Dogman_528
Nov 20, 2015 09:15 AM
specialpete2004
Aug 28, 2014 10:18 PM
Daz00Excursion
S. California Chapter
13
Aug 6, 2014 10:10 AM
