No start
Old May 6, 2021 | 08:36 AM
Ryan f250 4x4's Avatar
Ryan f250 4x4
No start
Was driving home about an hour drive the truck got lazy and and missfired abit got home shut it off no re start it got firm voltage and Sync and all sensors are reading properly I did do blue spring upgrade last week broken spring maybe ?
Old May 6, 2021 | 09:31 AM
bismic's Avatar
bismic
Instead of saying "all sensors are reading correctly", how about providing numbers?
Maybe someone here can see something that you, or others, might have missed.
KOEO:
ICP pressure
ICP volts
Cranking:
ICP pressure
ICP volts
IPR % duty cycle
Cam/Crank sync
FICM sync
FICM MPower
FICM LPower
cranking rpms
Vref voltage
I assume that you haven't seen any DTC's, so please post up what tool you are using to scan the PCM with.
Old May 6, 2021 | 12:09 PM
Ryan f250 4x4
I don't remember off the top of my head but I had use of a snap on scanner
Old May 6, 2021 | 12:14 PM
bismic's Avatar
bismic
Thanks. Please post the requested data and we should be able to help (and avoid guessing).
Old May 6, 2021 | 01:59 PM
LouWap22's Avatar
LouWap22
+1 with Bismic, Need values so we can tell you whats off and on point. Good luck!
Old May 6, 2021 | 11:15 PM
IHateCommieCars's Avatar
IHateCommieCars
Definitely need data, but while your getting that, if you want to take the cap off your fuel bowl, you can confirm that it's filling up quickly with strong fuel pressure.
Sailor Roy
Montana Chapter
308
Nov 1, 2020 02:13 PM
Daz00Excursion
S. California Chapter
13
Aug 6, 2014 10:10 AM
donjamer
Massachusetts Chapter
1416
Mar 15, 2012 08:55 PM
MisterCMK
Minnesota Chapter
1359
Feb 28, 2011 10:03 PM
bassproguy07
The Next Generation
Mar 28, 2006 11:56 PM
