Pitman arm
Old Oct 10, 2022 | 06:14 PM
5speed65's Avatar
5speed65
Pitman arm
I was trying to rebuild my stock 3 bolt horizontal box but cannnot find the seals anywhere
so I’m thinking I might convert to 78-79 power box. Does anyone have a pitman arm they want to get rid off?
Old Oct 11, 2022 | 08:49 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
It’s done before with the box on the bench, can be done on vehicle. Remove the pitman arm (with an actual pitman arm puller NOT a tie rod end fork ) from the steering box output shaft (sector shaft), then there's a snap ring that needs to be removed. Once that's out of the way there is a washer, then a seal, then another washer and another seal.
Remove the first washer exposing the first seal. Take a sharp center punch and pierce the seal, screw in a sheet metal screw and pry the seal out. You can do two screws 180 degrees apart too. Once the first seal is out, remove the second washer and repeat the process. (you can also try just removing the snap ring, (after the pitman arm is off) turn the wheel to the left and start the engine, it will usually blow the whole thing out, both seals and spacers but you better have a huge drain tray under it, then reassemble.) SEE ADVICE BELOW.
To replace the seals, apply a thin coating of grease to the inner lip of the seal and a thin coat of sealer to the outside diameter of the seal (I like No. 2 Permatex non-hardening). Slide the seal over the shaft and take a deep socket that’s just slightly smaller than the OD of the seal and drive the seal in until it seats. Replace the washer then the next seal, washer then snap ring. Reinstall the pitman arm, hook up the steering linkage and that's it. If you don't have a socket that's deep enough you can use a piece of pipe or tubing too. The killer on these is getting everything centered. With the exception of the sector shaft Ford basically only sold the internals as an assembly.
The input shaft (F3AZ-3E502-A) & sector shaft (D7AZ-3E501-A) seal kits are available from Ford and auto parts stores. Seal kit, steering gear sector shaft
Parts list #64, With gear ID SPA-AB, AJ, AN, BN, BS, BX, CC, CN
Basically this covers all 73-79 2WD F100-350 w/
powersteering
D7AZ-3E501-A.. Sector Shaft Seal Kit
Last dealer cost $29.41 List $43.71
So try the dealership OR ……
Parts International, Farmers Branch, TX has 50 (972) 241-8730
Green Sales, Cincinnati, OH has 19 (800) 543-4959
Manderbach Ford, Temple, PA has 5 (610) 929-3683
Freese Motor Inc., Monticello, IA has 4 (319) 465-3541
Herb Chambers Ford, Westboro, MA has 2 (508) 366-8311
https://www.ford-trucks.com/forums/1...+steering+seal
Steering box input seal…piece of cake 30 minutes 78 F250. Try dealership OR Autozone part # 8520 $8.99 in stock. Ford part # F3AZ-3E502-AInput Shaft Seal Kit…Unndo bolt at rag joint, remove plastic cover on steering column (in cab) loosen steering column bolts (2 bolts to dash) pull up on column and disconnect rag joint from steering box. Drill small hole in dust seal on steering box & screw a screw in and remove seal remove snap ring, drill hole in seal remove with screw. Replace seal, snap ring, dust seal and reconnect steering column.
ADVICE: Remove the pitman arm. Remove the snap ring. Thread the nut back on just a couple of turns. Crank the engine, and turn the steering wheel from stop to stop, until the pump pressure pops the seals and spacers out. The nut keeps the seals and spacers on the shaft, in correct order and orientation.
Keep your old seals and spacers. Lay them out, in order, and oriented correctly, and then photograph them. You may need some of them. The kit can come with different thickness spacers, and might not be the same as the old ones. Fortunately, the spacers can be reused. The nut on pressure removal trick keep you from using a screw to remove both seals and possible save one.
Old Oct 11, 2022 | 09:29 AM
5speed65's Avatar
5speed65
powersteering
Its a manual box that has the horizontal output shaft so there is no seals available
Old Oct 11, 2022 | 09:55 AM
77&79F250's Avatar
77&79F250
So A for effort, but D- for application, got it. So you need a seal for a 3 bolt horizontal (mounted?) steering box, w/manual steering and a horizontal output shaft. It is not that there is NO seal available, you have just not found it yet.
Maybe get you going in the right direction. Yes he is talking 4x4 but? https://www.ford-trucks.com/forums/1...l#post16526692
https://www.partsgeek.com/pfzbrjv-fo...BoCZOUQAvD_BwE
https://www.ebay.com/itm/29338183231...RoCBBcQAvD_BwE
https://www.partsgeek.com/lnj1tvd-fo...RoCWAsQAvD_BwE
https://tomsoffroad.com/parts/66-77-...xoCbgwQAvD_BwE
thatK30guy
Oct 22, 2012 11:45 AM
DemonRace6
Oct 12, 2011 03:53 PM
DGMFORD
Jul 24, 2010 10:48 PM
fordguy300
Mar 21, 2009 12:52 AM
