'73 f100 4x4 rebuild kit manual steering box
Old 08-26-2016, 01:29 PM
Nick-1973-ford's Avatar
Nick-1973-ford
Nick-1973-ford is offline
Hi
I have more than an inch of play in my manual steering box. I could get a new one on summit or rockauto but was wondering if a rebuild kit is available or is it even worth rebuilding?
Nick
Old 08-26-2016, 02:09 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Nick-1973-ford
Hi
FoMoCo never offered a "rebuild" kit, all the parts were sold individually.
All the parts are now obsolete, some/all may be available NOS
Pic: 3552/3553 are the steering shaft bearing cups; 3571 are the bearings.
3576 is the sector shaft bushing, 3581 is the sector shaft gasket, 3591 is the seal.
But, a worn drag link and tie rods are another cause of loosey-goosey steering.
Does the truck have Power Assist P/S?
Old 08-26-2016, 08:38 PM
Nick-1973-ford
NumberDummy, yes. I have p/s assist which i just rebuilt. All tie rods are in great shape. I am putting new c bushings and radius arm bushings. But the problem is in the box.
Great diagram. I will use it. Thank you.
Old 08-26-2016, 08:50 PM
NumberDummy
Pic: Garrison Power Assist P/S Control Valve.
The (2) 3304 are what FoMoCo refers to as draglinks, have ball joints that wear out causing play.
Did you replace one or both when you rebuilt the steering?
Old 08-26-2016, 10:58 PM
Nick-1973-ford
I should have been more clear to answer your question. I have steer play when engine is off and p/s assist not in use. I can rotate the steering shaft attached to the steering gear with my hand and get play from it. In other words the play is pre-pitman arm - in the steering gear.
Thanks. I will look into the parts for that gear. My question - what parts in the steering gear do you think wear out (i know it is a shot in the dark) but i am sure it is a common problem. The owner before me did not use p/s assist - truck had no steering pump attached and ram cylinder was pouring out the fluid.
Nick
Old 08-27-2016, 09:04 AM
NumberDummy
Thanks. I will look into the parts for that gear. My question - what parts in the steering gear do you think wear out? I know it is a shot in the dark, but I am sure it is a common problem.
1966/75 F100 4WD: See pic below.
1) C6TZ-3552-A .. Lower Steering Shaft Bearing Cup / Obsolete
FREESE MOTORS in Monticello IA has 2 = 319-465-3541.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
MAINER FORD in Okarche OK has 3 = 405-263-7242.
1) C6TZ-3553-A .. Upper Steering Shaft Bearing Cup / Obsolete
MAINER FORD has 1.
CARPENTER has 4.
GREEN SALES CO. has 16.
2) C6TZ-3571-A .. Upper & Lower Steering Shaft Bearing / Obsolete
GREEN SALES CO. has 1.
CARPENTER has 2.
MAINER FORD has 2.
FREESE MOTORS has 2.
KAMA OBSOLETE PARTS in East Bethel MN has 4 = 763-434-0123.
2) C6TZ-3576-A .. Sector Shaft Bushing / Obsolete
GREEN SALES CO. has 6.
1) C6TZ-3581-A .. Sector Shaft Gasket / Obsolete
FREESE MOTORS has 1.
KAMA OBSOLETE has 1.
MAINER FORD has 2.
GREEN SALES CO. has 21.
1) C1TT-3591-G .. Sector Shaft Seal / Obsolete
SOEBY MOTOR CO. in Walhalla ND has 3 = 701-549-3711.
GREEN SALES CO. has 14.
1) C6TZ-3591-A .. Steering Shaft Seal / Obsolete
MAINER FORD has 1.
CARPENTER has 7.
1) C6TZ-3593-A .. Steering Shaft Gasket / Obsolete
MAINER FORD has 4.
GREEN SALES CO. has 17.
ahawes
19
06-16-2015 02:20 AM
Voh
08-16-2007 08:02 PM
packrat56
04-13-2007 02:51 PM
alpo23
12-09-2003 10:16 PM
Quick Reply: '73 f100 4x4 rebuild kit manual steering box
