Pistons not flush with block
Old Sep 30, 2022 | 02:51 PM
mtflat's Avatar
mtflat
I'm not sure what you're measuring "to the crown"?
Van Pelt's measurements are for diameter of the bore in a stock engine.
In order to use the same block and con rods, a Merc crank that is +1/4" requires a wrist pin placed higher on the piston so that it sits lower in the bore.
Along the lines of ebear, I'm thinking you have a Merc crank with Ford pistons.
edit: I measured some of both I have in the shop. The Merc pistons measure 1 1/2" from center of the wrist pin to the shoulder (top of the deck normally) and 1 5/8" to the crown of the piston.
Some early Ford pistons measure 1 5/8" center of the wrist pin to shoulder and 1 3/4" to the crown of the piston. This makes the Ford pistons sit 1/8" higher in the bore.
Old Sep 30, 2022 | 04:52 PM
bigwin56f100's Avatar
bigwin56f100
I'm going to guess as I'm not there to see everything nor am I a flat head guy, looks to me like it's a merc stroke that when assembled years ago they cut the tops of the pistons to the deck height desired for this engine. Is this a possibility?
If this is what they did, it was done to up the compression as if flatheads are like y blocks the piston sits down in the cylinder not at zero deck height
Old Sep 30, 2022 | 06:42 PM
HoraceFord's Avatar
HoraceFord
The real questions is where do I find pistons which are 1/8" shorter than the Ford pistons.
Measurements as I have them.
Width New - 3.209" Original 3.186"
Height New - 3.138" Original 3.065"
Center of pin to dome top - New - 1.750" Original 1.667"
Top of pin edge to edge of cylinder New - 1.278" Original 1.155"
I have the question submitted to Carpenter Ford and Van Pelt.
Thank you.
Old Sep 30, 2022 | 06:45 PM
52 Merc's Avatar
52 Merc
Have you measured your stroke yet? What did you find?
Old Sep 30, 2022 | 07:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If what you need is Mercury pistons, Egge and others have them: https://egge.com/?year_id=34791&make...vpf-ymm-search
You could also sell the Merc crank, get a Ford crank and use the Ford pistons.
Old Sep 30, 2022 | 08:17 PM
mtflat's Avatar
mtflat
You answered your own question. You need to order Mercury pistons for a 49-53 Mercury flathead that are + .030 which is a standard over-bore.
Old Oct 1, 2022 | 02:19 PM
HoraceFord's Avatar
HoraceFord
The stroke measures 3 3/4" but that is on top of the piston that is 1/8" too tall. The largest counter weight is 6" indicating a Merc crank. I've ordered a set of Mercury pistons from an outfit in Birmingham.
Thank you again for the advise.
Old Oct 1, 2022 | 02:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The piston wouldn't affect the measured stroke. 3-3/4" would be a Ford crank, I'm not seeing how that is possible. What is the distance from the edge of the piston to the deck, at bottom dead center?
Old Oct 4, 2022 | 04:05 PM
Larryjr03's Avatar
Larryjr03
Pistons not flush
Originally Posted by HoraceFord
I've been rebuilding my 1953 239 flathead V8. New pistons came from Dennis Carpenter. Used 8BA control rods purchased used on E-Bay. The crankshaft was machined for the mains .010, rods .020 and cylinders .030. Once installed the piston heads are about 1/8' above block at top.
What have I done and what can I do?
Looks to me from the picture of the 2 pistons side by side, it looks like you got the wrong pistons, manufactured incorrectly, or wrong part number from manufacturer.
Old Oct 10, 2022 | 03:23 PM
HoraceFord's Avatar
HoraceFord
Thank you for all the advice. It is amazing how easily the RIGHT PART makes a task go.
Thanks again.
Old Oct 10, 2022 | 04:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Plus the bonus of having a Merc motor!
Reconor
13
Sep 15, 2016 11:29 AM
cypher02334
Jun 3, 2015 10:40 PM
tom1979
16
Feb 14, 2007 09:35 AM
kevinupchurch
May 17, 2005 10:24 PM
wrangler76
Jan 21, 2004 06:41 PM
