Keep blowing ic boot off
Old Aug 27, 2022 | 05:41 AM
FinnishStroker's Avatar
FinnishStroker
Like this:
Old Aug 29, 2022 | 09:29 AM
BradyT88's Avatar
BradyT88
When I rebuilt my turbo I didn't clean my boots before reinstalling them and they had some oil on the inside from the CCV still being routed into the intake. First test run I popped the boot going from the cold side tube into the spider while it was pushing about 29 lbs of boost. Sounded like a gun shot. I put it back together and then drove it down the freeway the next day at 80 mph for a couple hours and then a couple days later drove it back home. Later on I turned the hot tune back on and put my foot into and it held 30 lbs of boost and now months later it still hasn't popped off again.
I'm not sure what boost level yours is popping off at, but if it's only when you are running higher levels of boost then I would follow @Sous advice above about trying to heat cycle it a few times at low boost. My speculation is that there was enough heat during those long sustained drives to get the oil sticky, but I don't know that the cold side actually gets hot enough to achieve that so you're mileage may vary. My brother-in-law has a 6.0 and a 6.4 and he said whenever he's had to remove a boot he just has to replace it because he's never had luck getting them to not pop off and he's tried all kinds of things like using hairspray and glues, etc.
Old Aug 30, 2022 | 05:19 AM
FordTruckNoob's Avatar
FordTruckNoob
The ultimate solution:
https://accufabracing.com/product/wi...v=7516fd43adaa
https://titanmotorsports.com/product...tube-connector
handifletch
Modular V10 (6.8l)
20
Apr 29, 2013 10:56 PM
ghunt
General Automotive Discussion
Jan 15, 2008 09:20 AM
mrl390
Nov 6, 2006 09:24 AM
Vanhecht
Exhaust Systems
Nov 2, 2003 03:06 PM
TRIMMAN98
May 7, 2002 11:00 AM
