?? heater hose valve ??
Old Nov 11, 2003 | 02:14 AM
78truckpower429's Avatar
78truckpower429
Im wondering if you dont have a vacuum line hooked up to the heater valve will it let water flow or does it not flow ...also where would the vaccum hose that goes to the valve come from ...like for instance from the firewall ..?? i have 1 big hose and a small hose that come out of the firewall but the small hose doesnt have any vaccum when i switch the selector in the cab ...and ideas..
Old Nov 11, 2003 | 05:19 AM
macguyver's Avatar
macguyver
No vacuum should default to "open". Unless the valve is stuck.
The vacuum hose routing I'm not sure about. I'd guess the larger hose going through the firewall should be connected to the "coffee" can (supply) and the smaller one to the heater valve.
diesel 04 X
Dec 1, 2024 10:24 PM
troy676
Feb 19, 2014 07:47 PM
ttttmaxx
46
Jun 20, 2012 11:28 AM
Randy777
Jun 7, 2010 10:21 PM
azwolfman
May 23, 2005 01:42 AM
