Water pump
Old Aug 13, 2022 | 02:09 PM
Xbolt's Avatar
Xbolt
4wd Low
Water pump
Anybody know how many hours (book rate) to change a water pump on 2012 F-150 5.0 ??? Have grinding noise like a dry bearing, took belts off and spun all all pulleys and everything seems fine except water pump pulley seems have to have alot of play but there hasn't been any coolant leaking. Ohh it,s ony noisey when and seems to go away once warmed up.
Old Aug 13, 2022 | 04:53 PM
RLXXI's Avatar
RLXXI
I don't have the labor guide handy but looking at the exploded view, it seems like a very easy job. Maybe an hour, hour and a half labor or so at most.
Old Aug 13, 2022 | 06:28 PM
Xbolt's Avatar
Xbolt
4wd Low
Thanks. I'm hoping it won't be over 2 I know most shop's go by the book. I know if I do this myself I'll run into issues and have to find a way to get to the part's store and this is my only driver so I can't be without a vehicle for very long. So I'm just trying weigh odds on wheather to do this myself otr take it in.
Old Aug 13, 2022 | 07:31 PM
RLXXI's Avatar
RLXXI
What ever you do get a Motorcraft/Ford pump, it should come with all associated o-rings required. No silicone sealant!!
Old Aug 13, 2022 | 11:08 PM
Xbolt's Avatar
Xbolt
4wd Low
Is there a problem getting one from Napa or Lordco ? The thing is will never ever darken the the doorway of my local dealship ever again and the nearest one is over 250 kms. away.
Old Aug 14, 2022 | 12:18 AM
RLXXI's Avatar
RLXXI
You can order it online and have it delivered. www.parts.ford.com and www.fordpartsgiant.com both sell genuine Ford parts. If that's absolutely out of the question I'd go with Napa's best warranty part. Never heard of the other one.
Old Aug 14, 2022 | 09:00 AM
Xbolt's Avatar
Xbolt
4wd Low
I'm in Canada so ordering fdrom the states is out of the question plus 2-3 week delivery. On Napa website theu have listed a new and remanufactured ones with both being similar in price.
Old Aug 14, 2022 | 10:12 AM
gDMJoe's Avatar
gDMJoe
Lightbulb
Xbolt...
As a newbie... Consider putting your complete vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, maintenance, modifications, etc., etc.) in your signature to have it automagically included when you post. *Eliminates playing 20 questions when/if a post is made pertaining to your vehicle.
» Edit Signature ««« -click-
*Don't forget to [ save ] it.
Old Aug 15, 2022 | 05:47 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
My local dealer will go to the napa store around the corner from time to time if the MC part needed isn't readily available, the only issue is that they can't or won't warranty it the same.
Considering the high failure rate of the early 5.0L water pumps, paying the huge bucks for yet another MC water pump isn't exactly inspiring confidence.
Old Aug 15, 2022 | 06:57 AM
BassFantasizer's Avatar
BassFantasizer
I put a water pump on my 5.0L 2014 about a year ago. It was the first water pump I've replaced in a very long time, still, everything came apart and went back together in my driveway in under 2 hours.
I don't know what the book rate is, but if you want to do this yourself it's not a bad chore. My only gripe was that the bottom pulley is so close to the harmonic balancer that it has to come off to fully remove the serpentine belt.
Good Luck!
fastback89
2009 - 2014 F150
Jan 19, 2016 04:43 AM
BuckHammer
135
Jun 9, 2012 11:35 AM
One Sock
Feb 14, 2012 09:23 AM
true blue
Jan 20, 2011 09:36 AM
ginsan67
Aerostar
May 1, 2005 07:42 PM
