5.0 Water Pump
Old Dec 4, 2015 | 08:40 PM
fastback89's Avatar
fastback89
5.0 Water Pump
I replaced a water pump on a customers 2013 5.0L truck this week. The bearing was totally shot and lost all the coolant. Truck only had 46000 miles on it, is this common?
Old Dec 4, 2015 | 09:39 PM
Puddy's Avatar
Puddy
Same thing happened to a co worker of mine, had his replaced around 140000km
Old Dec 5, 2015 | 04:34 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
First I've read of newer engine water pump failures.
Old Dec 5, 2015 | 08:05 AM
Tom's Avatar
Tom
Is the 5.0L water pump belt or chain driven? The V6es have a water pump that's driven by the timing chain which is a much more involved procedure to change. It also dumps the coolant directly into the engine oil when it fails. NOT my favorite design.
Old Dec 5, 2015 | 10:08 AM
Puddy's Avatar
Puddy
Good ole serp belt setup
Old Jan 18, 2016 | 07:45 PM
Tom's Avatar
Tom
Just wanted to update this thread to correct some bad info:
This is WRONG. Turns out the Duratec and EcoBoost V6es used in the cars has this design, but the engines used in the F150 are traditional belt-driven pumps. Got to thinking about this, looked up some part numbers, and then went outside with a flashlight and confirmed on my truck. The water pump is in the traditional location and doesn't look like a big deal to change.
Old Jan 18, 2016 | 10:05 PM
m-chan68's Avatar
m-chan68
To make things simpler, the 3.5/3.7 V6s used in front wheel drive applications (eg. Taurus/MKS, Edge/MKX, Flex/MKT and Explorer) use a timing chain driven setup as described in post #4 of this thread. But on rear wheel drive applications (eg. Mustang, F-150 and Transit) they are externally belt driven as described by the post in quote above, while a dummy idler sprocket resides in the position inside the engine where the water pump would be on the FWD engines.
Back to the original post topic, I just replaced one on a 5.0L F-150 having the exact same failure as described in post #1 about two weeks ago. Since we're on the topic of the 5.0L, also noteworthy of common coolant leaks is the block heaters on these engines, a repair that isn't quite as easy as the water pump.
Old Jan 19, 2016 | 04:43 AM
tseekins's Avatar
tseekins
Thanks for clearing that up sir, reps sent.
Pele
2011 - 2019 Explorer
34
Jan 26, 2021 05:40 PM
Epd444
Apr 26, 2012 11:18 AM
One Sock
Feb 14, 2012 09:23 AM
shoebear
May 2, 2010 05:43 PM
just_waitin
Jun 18, 2007 10:39 PM
