Question about lifter failure
Old Jul 25, 2022 | 12:02 PM
Pascal2803's Avatar
Pascal2803
6th Gear
Hi!
I have an ‘09 E350 with 140k miles. There is a chirping noise happening at low rpm when the engine is hot. (
). It increases in speed with increase in engine RPM. I searched around and found other videos with a similar sound and the culprit was a failing lifter. From my understanding , the sound is the lifter grinding the camshaft. I have driven about 3k miles since the noise started.
I went to the dealership and they couldn’t diagnose what was the issue and said the truck was “fine”. All cylinders were performing the same on the contribution test. I don’t agree with their statement of the trucks being fine.
Here are some options that I was thinking and would like people opinions on them.
1. I have found a used engine for 2k (09’, 105k miles) and could swap it now or wait until the current one is broken.
2. Pull the engine out, Do a HG job, put ARP studs and replace all the lifters. Keep the same camshaft
3. Same as 2 but replace the camshaft
4. Do nothing as the dealership said because the truck is running fine and wait for other symptoms to appear.
Looking for other ideas/advice.
thank you,
Pascal
Old Jul 25, 2022 | 06:05 PM
Yahiko's Avatar
Yahiko
If the lifter is failing and grinding the cam. You are going to want to replace the cam and clean the block oil passages. In other words a rebuild.
Option #1 if it's the 6.0L.
You can drain the oil and check for fragments of the needle bearings on the magnet and in the oil.
Also, you can pull the filter out and run a magnet around the inside of the filter housing bottom to see
if there are any fragments in the oil in there. If you want to go deeper, you can pull the HOP cover
and look at the cam. You may even be able to see the other lobes of the cam with a borescope.
You will have to snake it under where the turbo base mounts to the block.
Old Jul 25, 2022 | 11:31 PM
Hartwig's Avatar
Hartwig
If it is ensured that the replacement engine will work properly, #1 is the cheapest solution.
I would first remove the valve covers and make sure the problem is not just a rocker arm or something. (I know it's a van, it requires rotating the engine a bit). Also check the base oil pressure. To be on the safe side, also check the vacuum pump and start the engine without serpentine belt (just to make sure it's not something simple).
Old Jul 27, 2022 | 02:50 PM
LindenBruce's Avatar
LindenBruce
My money is on an idler or tensioner pulley. Give Hartwigs suggestion of removing the belt before spending money on something you don't need. B.
Old Jul 29, 2022 | 08:08 AM
HydroTek's Avatar
HydroTek
Does that sound change or go away when you put the trans in gear ?
sounds more like a flex plate to me
Old Jul 29, 2022 | 10:38 AM
MisterCMK's Avatar
MisterCMK
Is there metal in the oil filter?
Old Jul 29, 2022 | 04:09 PM
Pascal2803's Avatar
Pascal2803
6th Gear
Thanks for everyone’s advice. Will be trying to start the engine without the belt this weekend. I will also look for metal particles in the oil filter.
The sound happens when it is in drive or park. It is audible below 1000 rpm and only starts after 15/20 min of driving/idling. Starts off quietly but gets to the same level as in the video after another 15 min of driving/idling. It doesn’t make the sound at all when first started the following day.
Old Jul 31, 2022 | 04:06 PM
Pascal2803's Avatar
Pascal2803
6th Gear
tested without the serpentine belt and it stills made the sound. I haven’t tested with removing the second alternator belt yet.
Old Jul 31, 2022 | 07:34 PM
m-chan68's Avatar
m-chan68
Is this a former ambulance by any chance?🤮🤮🤮
Old Jul 31, 2022 | 07:47 PM
Pascal2803's Avatar
Pascal2803
6th Gear
It is, quite a pain to work on.
Old Aug 1, 2022 | 02:03 AM
Hartwig's Avatar
Hartwig
Any codes?
Do relative compression test with Ford IDS.
Is it a bad maintained engine?
Old Aug 1, 2022 | 02:16 AM
Hartwig's Avatar
Hartwig
I got the small lifter problem fixed on this 2006 E350 with an oil change twice. The problem here was dirt in the oil.
Old Aug 1, 2022 | 06:10 AM
Pascal2803's Avatar
Pascal2803
6th Gear
Originally Posted by Hartwig;[url=tel:20499442
20499442[/url]]Any codes?
no codes, the relative compression showed all cylinder to be good and within 5% of each other.
For the maintenance, I’ve only had the truck for two years and it was previously a training ambulance at a school. Wouldn’t know if they cheap out on the maintenance.
Old Aug 1, 2022 | 06:12 AM
Pascal2803's Avatar
Pascal2803
6th Gear
Originally Posted by Hartwig;[url=tel:20499444
20499444[/url]]I got the small lifter problem fixed on this 2006 E350 with an oil change twice. The problem here was dirt in the oil.
https://youtu.be/jhfP1b_aoOo
Definitely a possibility. Will give it a shot. What oil did you use?
Old Aug 2, 2022 | 06:09 AM
Hartwig's Avatar
Hartwig
fullsynthetic 10W-40 (German spec.)
Guitarguy
1983 - 2012 Ranger & B-Series
Jan 6, 2008 03:08 PM
tombob
1978 - 1996 Big Bronco
Dec 24, 2002 01:14 PM
tombob
Dec 13, 2002 07:54 AM
cgl
Dec 25, 2000 02:15 PM
