Back fuel gauge problem
Old Jul 11, 2022 | 06:20 PM
KyleRepass's Avatar
KyleRepass
5th Gear
Whenever I switch it to the back it goes all the way up but has no gas on it but the front seems to work okay maybe a little off
Old Jul 12, 2022 | 06:04 AM
jas88's Avatar
jas88
It has lost connection to the sender or sender is bad.
Old Jul 12, 2022 | 03:46 PM
rla2005's Avatar
rla2005
What year/model/engine truck are you working on?
Old Jul 12, 2022 | 07:03 PM
KyleRepass's Avatar
KyleRepass
5th Gear
it’s a 1992 f150 5.0 v8 where is the sensor for it or link a video I can’t find one
KyleRepass's Avatar
KyleRepass
5th Gear
where is that located or link a video I can’t find one
Old Jul 13, 2022 | 10:20 AM
jas88's Avatar
jas88
The sender is in the tank incorporated with the fuel pump.
Old Jul 13, 2022 | 10:45 AM
rla2005's Avatar
rla2005
As stated previously each tank has it's own fuel level sender as well as high pressure fuel pump. The selector switch on the dash has two sets of contacts. One set for the fuel sender and the other set to power the selected tank's pump. You can measure the fuel sender resistance at the tank selector switch using a meter (DVM) set to ohms. Typical resistance range is 22.5 ohms (empty) to 145 ohms (full). With an open circuit/very high resistance the fuel level gauge will peg past full.
KyleRepass
Jul 11, 2022 05:57 AM
Brad Brown
Jan 27, 2022 07:21 AM
Tvertiz
6.7L Power Stroke Diesel
Aug 15, 2016 03:17 PM
OrdoDraconis
Apr 17, 2005 09:02 PM
