Outer door window scraper
Old Jul 12, 2022 | 09:33 AM
69torino's Avatar
69torino
Well, thats what Rock Auto calls them at least. The outer weather-strip piece that sort of resembles a hockey stick is what I have just ordered , mine are cracked bad. just curious if anyone here has used the Fairchild F2005 and F2006 part # pieces and how the fit and quality was ?
Old Jul 12, 2022 | 09:35 AM
69torino's Avatar
69torino
https://www.rockauto.com/en/moreinfo...1430&jsn=10527
Old Jul 12, 2022 | 09:50 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I would not want it to scrape my windows. I always heard them called belt moldings. I don’t have any experience with Fairchild but I do with Precision brand. The belt molding/ window scrapers and door seals are good quality.
Old Jul 12, 2022 | 09:55 AM
69torino's Avatar
69torino
Thanks for the reply. I have seen Rock Auto use both window scraper and belt molding for part names. I went for the Fairchild pieces as they are less expensive. My truck is winter stored , so just gets rain and wash water on it now. I am actually going to have my body shop buddy install them for me to make sure they go on correct.
Old Jul 12, 2022 | 10:18 AM
Hit Man X's Avatar
Hit Man X
The ones from Cockauto seem fine that I installed on my '92. Only been on there about six months I think.
Old Jul 12, 2022 | 11:24 AM
blazerman07's Avatar
blazerman07
Same ones I put on in October. They are good quality and fit perfect.
Old Jul 12, 2022 | 01:43 PM
wwhite's Avatar
wwhite
I put those on last year, better not perfect.
The clips that fit the door panels were a tiny bit different, and my door panels are broke where the clips go in.
Old Jul 12, 2022 | 03:34 PM
69torino's Avatar
69torino
Thanks guys, just waiting for Fed X to deliver them. They come with the whatever clips are required to install them ? The picture on the Rock auto website appears to show them as part of the structure.
Old Jul 12, 2022 | 03:48 PM
wwhite's Avatar
wwhite
Yes, should be part of the new part. I ended up taking my door panels of to remove and replace the outside ones, and also the inside ones. The outside ones were easier to install as the clips go on to the metal part of door, inside are on plastic door panels.
Old Jul 12, 2022 | 04:05 PM
My4Fordtrucks
The clips are stapled to the molding.
Old Jul 13, 2022 | 08:34 AM
69torino's Avatar
69torino
thanks guys.
Old Jul 13, 2022 | 09:46 AM
emeraldcoupe's Avatar
emeraldcoupe
please update when you put them on, i'm needing a new set for my truck also.
Old Jul 13, 2022 | 10:30 AM
Scndsin's Avatar
Scndsin
It was tedious, but I drilled the inner & outer window felts/rubbers (whatever you want to call them) for 3 small round head sheet metal screws from my hardware collection.
No more depending on the tabs/clips which crumble & break much faster than the stock pieces ever thought about, regardless of who makes them.
Just a thought for you.
Old Jul 13, 2022 | 12:07 PM
69torino's Avatar
69torino
thanks, I am having my body shop friend install them as part of some touch up paint work he will be doing also.
dharte
Nov 11, 2014 11:17 PM
92F150Flare
Mar 13, 2007 10:50 AM
460
Jul 12, 2006 01:53 AM
Push2Shv
Aerostar
Dec 21, 2002 06:25 AM
