fuel gauge
Old Apr 17, 2005 | 08:27 PM
OrdoDraconis's Avatar
OrdoDraconis
Cool fuel gauge
well for some reason my fuel gauge is not working i do have dual takes with the switch the likely ness that both sending units went out is very small and usally gauges dont go out for a while in my experience but you never know what would be a good way to check the fuel gauge or could the problem be the switch cause it has never been the changed out?
Old Apr 17, 2005 | 08:57 PM
Popa Tim's Avatar
Popa Tim
The problem is likely the switch, which can be ohmed out or continuity tested with most digital meters.
Old Apr 17, 2005 | 09:02 PM
OrdoDraconis
thank you
thank you for the fast response ill look into it i was jsut gonna replace that any ways
