Gauge programming
Old Jan 26, 2022 | 12:27 AM
Brad Brown's Avatar
Brad Brown
Gauge programming
Guys, is there anyway you can get the fuel and the def gauge to switch spots. I keep thinking the def is the gas. If not, they should do it!
Old Jan 26, 2022 | 07:05 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
No way that I know of.
You can swap the DEF gauge for trans temp.
Old Jan 26, 2022 | 08:38 AM
DecodanMcQ's Avatar
DecodanMcQ
Not trying to hijack but this question fits title. How do you get actual oil pressure to show above the oil High/Low scale on ‘22 F-350 platinum with 6.7. I have seen pictures of this. And can I get gallons of fuel used like I had in my ‘16 F-250. Thanks for any help. Getting ready for a 5k mile trip.
Old Jan 26, 2022 | 08:39 AM
Beast2.0's Avatar
Beast2.0
On my '18, I was able to do that with ForScan
Old Jan 26, 2022 | 08:58 AM
Brad Brown's Avatar
Brad Brown
I did see that swap, but i would still love the fuel on the end. what a bummer, I may have to put a sticker on it! I almost ran right out of fuel. THAT would be a bad day I am assuming. Thanks anyways.
Old Jan 26, 2022 | 09:01 AM
4wd6.7L's Avatar
4wd6.7L
To the OP, the only gauge that can be changed is the far right one. Not the location though. Turbo boost, trans temp and def level. Maybe changing it to trans temp or turbo boost would be better for you.
On my 19, using FORScan to put numbers above gauges did not include oil pressure.. L-H is all we get.
Beast2.0's Avatar
Beast2.0
I may be wrong but can you not put Fuel and DEF next to each other?
Old Jan 26, 2022 | 09:04 AM
Brad Brown's Avatar
Brad Brown
you can, but the fuel is on the left and the def is on the right. I was trying to get the fuel to the right which I guess is a no go. Bummer. as that is where my eye goes every time to check the fuel. for some reason.
Old Jan 26, 2022 | 09:32 AM
Beast2.0's Avatar
Beast2.0
You'll get used to it. You'll look at the fuel gauge cuz DEF hardly moves.
Old Jan 26, 2022 | 10:15 AM
h20camper's Avatar
h20camper
I would think the DTE number above the fuel gauge would catch your eye.
Old Jan 26, 2022 | 07:48 PM
KU4OJ's Avatar
KU4OJ
It's the same with the 4.2" screen with real gauges as well. The gas gauge is in the middle of the pack. If they'd bothered to ask me, It would be on one end or the other.
They never ask me these things...
Old Jan 27, 2022 | 07:21 AM
B-ManFX4's Avatar
B-ManFX4
No dice on the oil pressure number display. No code for it in Forscan and the truck uses a simple pressure switch for the oil gauge - oil pressure when running = good, no oil pressure when running = bad. Nothing in between. That's why the gauge runs in the exact center and never moves. If you enable oil temperature monitoring via the menu pick in Forscan there is no sensor for it and the truck will tell you the oil is -76°.
Gicknordon
Oct 30, 2016 08:22 PM
jrcbfun
Apr 14, 2007 10:52 PM
frachubb
Bronco II
Oct 28, 2003 08:44 AM
