2016 mainly highway miles no recent towing, regens always 500 miles apart. Most recent regen lasted 50 miles. Of course after a 1.5 hour drive, it started the second I pulled into a parking lot. Shut it down right away bc i don't care anymore..... Anyway after a day trailriding, the truck immediately starts exhaust cleaning on the journey home. 15 miles on twisty country roads so exhaust took forever to warm up, dpf % didn't change. Once cruising 75mph on the interstate it started going down. Hope it's not a sign of future issues. Crushed my mpg and a 1/4 tank.
So you mean you were driving the trails in the Super Duty? If so, I'm thinking all those slow speeds and crawling really loaded up the DPF... SL % won't drop until ETGT4 gets up there some... BTW, how many miles on the truck? A Banks iDash or similiar monitor does wonders to let you know when an active regen is imminent.
Great point, but no, the truck was just parked. I was dirt biking. Has 99k. I have torque pro but wasn't able to monitor temps this time since my tablet was out of battery.
Maybe it was because the dirt road you were on prevented the filter from getting hot enough to start burning off the soot and it loaded it up even more so when you hit the highway, it took longer... Who knows? I'm just guessing.
I was driving along and my soot level started to slowly tick backwards from 36% , 35%, 34%, 33%, and finally by the time I parked it was 32%. I started to theorize why suddenly the truck passive regens.
the next day, I started the truck and the soot level was 42%
so I’m now concluding. …the reduction in soot was really just a reduction In back pressure and that was due to a hot dpf vs a warm one vs a cold one.
so some of these passive regen reports are false and actually differences in back pressure with the same soot load.
Yeah I've seen that too and I think you have a point (about the iDash). When I'm driving in to work on expressway (altitude drops, engine works less, DPF stays cooler) so the iDash climbs fairly quickly.
Driving home (altitude climbs, engine works harder, DPF gets hotter) so iDash reduces some or sometimes just stays the same number for SL %.
This has to mean something because it makes sense that soot will increase when the filter is cooler and not increase or even reduce a little when hotter.
As to seeing it increase or even decrease (the iDash) on the next day, that I have not seen.
What I have seen is the truck SL % decrease by 5% the next day (after an active regen) once it cools and is cold when started the next day. But it usually climbs back up 5% fairly quickly after that.
