Regen cycles
Old Jul 6, 2022 | 07:41 PM
Just Chilling's Avatar
Just Chilling
Regen cycles
2017 f350. 210k miles
I used to be able to go 500 miles consistently before regen.
Over the last 2 months it has been steadily declining and I am now down to every 200 miles.
I had a derringer tuner on and started to have the p0087 code come on and engine would derate power but it was only during a regen cycle. Took it in and injectors all passed their balance testing, they pulled sensor on the fuel rail and checked for filings, all clear.
They replaced the sensor since it was off and relatively cheap, all replaced fuel regulating valve to since it was fairly cheap and they said it can sometimes stick.
Went through another regen and it did it again and this time I was watching my idash and commanded psi was 3k higher than actual pressure. I removed derringer and it has not done that again.
But my regens are at 200 miles and dropping.
Any ideas. No codes and runs fine.
Old Jul 6, 2022 | 08:23 PM
Overkill2's Avatar
Overkill2
Check this out about not just replacing the sensor but the whole fuel rail.
https://www.forddoctorsdts.com/forum...87-code-on-67/
Old Jul 6, 2022 | 08:40 PM
Just Chilling
Will that affect my regen cycles dropping to 200 miles.
I have logged about 700 miles since removing the derringer and have not had low fuel pressure since.
As of now I am more worried about regen cycles.
Old Jul 6, 2022 | 09:00 PM
FishOnOne's Avatar
FishOnOne
Is the miles required to complete a regen still the same?
Old Jul 6, 2022 | 09:05 PM
Just Chilling
I think it may be a little higher. I did notice that when it hits 100 it will trigger a regen then as it is heating up it skyrockets to 105 or 106 hangs there for sometime then comes down to 23 or so and shuts off.
it never did go below 20 since it was new so wasn’t to worried about that.
Old Jul 6, 2022 | 09:15 PM
FishOnOne's Avatar
FishOnOne
I had a similar problem years ago when I noticed my regens was occurring more frequent and the root cause was a defective EGT sensor was not allowing a complete regen process. Some things to consider source of fuel and summer heat can increase regen frequency.
Old Jul 6, 2022 | 09:32 PM
Just Chilling
I did not realize that summer heat would affect it. That could be it as it has been very warm and humid the past couple weeks.
I am getting fuel at the same stations I always have but who knows what quality and availability is happening nowadays.
Old Jul 6, 2022 | 10:07 PM
FishOnOne's Avatar
FishOnOne
Yep... Heat and Humidity sure does increase my regen frequency. And here in the last month, I noticed the fuel I'm getting made my engine a little noisier. So, I tried 8 oz of Power Service fuel additive and made my engine nice a quit again but did nothing on the regen frequency.
Old Jul 7, 2022 | 06:54 AM
speakerfritz's Avatar
speakerfritz
I was going to buy a derringer tuner, but after the fact that they have not answered my emails and this thread...decided not to.
the derringer tuner is supposed to optimize the fuel burn and ensure that the burn is complete which would theoretically mean more miles between regens not less miles between regens. what has Banks have to say about this? I hope they answer your emails.
if you did not have a derringer tuner, I would have suggested you clean or replace your MAP sensor.
Old Jul 7, 2022 | 10:27 AM
Just Chilling
I am not yet faulting the derringer, I removed it out of caution and one less possibility for failure right now.
while heat and humidity may play a factor I still think it more than that right now, if there were some codes I would have a place to start.
Fuel mileage and everything is normal. It went through a regen first thing this morning got down to 23 percent 65 miles later it’s back up to 47. And 13.5 mpg.
Old Jul 7, 2022 | 07:22 PM
Overkill2's Avatar
Overkill2
I wonder if your DPF is starting to fill up possibly bringing down your regen cycle mileage. How do you use your truck? DD or do you tow some? Has your mileage dropped as well?
Old Jul 7, 2022 | 08:05 PM
Just Chilling
DD, I have an 9 ft enclose utility box and run mostly hw miles. Weights almost 10k lbs plus hook to heavy farm equipment and trailers quite frequently gross 20k plus lbs.
Although it’s titled a 17 I ordered it in October on the last day they closed the order banks and received it in nov. so it’s basically an 18.
So no it does not sit around.
mpg is the same 13.5 like it has always been. I did some reading on map sensors and it says if going bad and or plugged it can overload egr system it’s only $70 so I picked on up and am going to change it.
This came on just about overnight, it was a distinct change.
Old Jul 7, 2022 | 08:11 PM
Overkill2's Avatar
Overkill2
You should try cleaning it if you haven't already. Let us know how you make out.
Old Jul 7, 2022 | 09:20 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Not to derail this thread, but I am a bit disappointed in their (Banks) responses to. I sent them a message about some issues I am having with an iDash some time ago and they have been very slow to respond, and then the response was a question to me that was answered in the original email… so now I am waiting to hear back again… it’s been 9 days this time… their lack of response (and this issue) kept me from picking up a pedal monster over the 4th weekend too… I gotta say, I thought more of them, until I actually needed them.
Anyway, curious to hear if the map sensor does it. Maybe this would be a good spare to have on hand?
Old Jul 8, 2022 | 04:32 PM
Just Chilling
Got around to replacing map sensor.
Im not that familiar with how much carbon can be on them and they still register properly.
