My regens are always shorter when they happen in town as opposed to on the highway. My guess is that the increased air flow across the exhaust on the highway keeps the exhaust temp down. Higher temp = quicker regen.
I might have to try the "square" route I have done before where I make right hand turns on local roads and speeds are 45 to 50 mph but I can 60 mph. I'd be curious to see if the miles would be lower due to the lower speeds and once hot, the DPF could burn down the soot when at red lights.
Regen today. Ambient temperature was 96°F to 99°F as reported by the truck. City driving at 45 MPH or less, with a few stoplights in the mix. 100% to 20% regen took 16 miles. Normally my regens go to 0% but either it really was done at 20% or I just didn't wait long enough for it to go down further. Oh, and I was towing my bumper pull toy hauler that likely weighed in at 10K.
Pulling the trailer means your EGT's should have been high enough to passively regen anyway.
There's no way my truck is going to passively regen 80% of the DPF. I've seen a passive regen register on the gauge exactly once and that was a whopping 5%.
I have never seen a passive regen and I have pulled heavy trailers and towed heavy farm equipment that probably should not have been towed by a superduty.
My egt have been up in the 950s but not very long. Only thing I can figure out is Ohio is flat enough that temps are not hot enough for long enough and has enough stop and go that what happens to burn off is just replaced taking off from the next red light.
I am cautiously optimistic that the map sensor has fixed it. Have not really had any good runs lately but did get a long enough regen to get it down to 32 percent. Then I was able to get another 300 miles before it was full again. That was a big improvement over 23 percent to full in 200 miles.
I also noticed that the last time when it regened that it did not overshoot to 106 percent at the start either.
Also it has been climbing slower on cold starts. I would always climb 6 points or so every time I would do run after setting an hour or so.
I still have the derringer disconnected I want to give it sometime before reinstalling it.
I have never seen a passive regen and I have pulled heavy trailers and towed heavy farm equipment .
Then your truck is broke! If EGT's are north of 580 then the DPF is in a passive regen. Of course you will need something to monitor the soot load in order to see it.
I see it it on a daily basis on flat expressways at 65 with 6500lbs behind me.
I quite often pull heavy and hard, while there is passive regen i am pumping enough fuel to increase the soot faster than it can passively regen. I have even had active regens abort towing heavy loads up long grades.
I quite often pull heavy and hard, while there is passive regen i am pumping enough fuel to increase the soot faster than it can passively regen. I have even had active regens abort towing heavy loads up lo g grades.
Definitely certain driving conditions will create more soot than it can passively Regen.
The user I was quoting stated he had never seen a passive regen in 5 years a ownership. That's highly unlikely either his truck is broke which is unlikely or he just hasn't seen it which is highly possible.
The owners manual, specifically the diesel supplement even States passive regeneration does take place under the right driving conditions.
I watched my DPF count down from 55% to 0 driving 70 miles with our 6000 lb camper behind us. My auto regen was turned off, so it was a passive regen. Also, when towing our camper longer distances, my DPF stays at 0 the entire time, again with my auto regen turned off. Maybe it’s heavy enough to passively regen the DPF, but not heavy enough to produce more than what the temps can passively regen away?
Thats excellent results. Just a reminder to this group that the 20+ models have higher injection pressures, lower compression and improved fuel economy which probably means less soot produced so how the truck deals with soot in the DPF maybe a bit easier to manage.
I have been driving my truck fairly mixed the last couple of weeks, some in town , some highway, a few short trips with the 5er (60 miles each way) managed to get 1437 miles before I got the regen needed message. I run B-20 or slightly higher since it’s wam out and use hotshots edt. The observations here are interesting…
I'm on my phone right now so I'll assume you have a MY 20 plus because of the high amount of mileage there to get to an active regen.
These 20 plus trucks are amazing to me as it seems that Ford has got it right when it comes to the new strategies of higher fuel pressures, lower EGR use and higher DEF use to get these trucks to be highly efficient at going long distances without active regens saving on fuel.
IMO, unless one wants to build a high power pull truck, dyno truck or track truck, there really appears to be no reason to delete a 20 plus, barring any unsolved issues, if the truck is being used the way it was designed for.
