Sponsored by: Real Truck
Transmission Problems
Old Jun 28, 2022 | 10:10 AM
fpt2's Avatar
fpt2
Having a lot of hestiation when coming to a stop and going through 1st and 2nd gears, blinking O/D light, etc. Everything seems fine once I'm at 20mph or so. Scanned with Forscan and the codes it gives are P0503, P0720, P0722. I've changed out the input and output sensors in the transmission as well as completely replaced the wiring harness (from the engine bay all the way back to the rear output sensor). Anyone have an idea on what to check/change out next?
Old Jun 28, 2022 | 10:45 AM
bwguardian's Avatar
bwguardian
...it would help tremendously to know what transmission and/or year model and power plant you have as the transmissions are different...
Old Jun 28, 2022 | 10:53 AM
fpt2's Avatar
fpt2
My bad thought it was in my signature
2001 F250 5.4 2WD
Old Jun 28, 2022 | 11:56 AM
Mike1's Avatar
Mike1
Well...According to the guy in this video, it's your alternator causing the problems....Watch the video make up your own mind.
Old Jun 28, 2022 | 05:19 PM
fpt2's Avatar
fpt2
That is not what I would have suspected, thanks! I’ll give this a look.
Old Jul 1, 2022 | 07:51 PM
fpt2's Avatar
fpt2
Thanks Mike!! I picked up a new alternator and installed it today and everything is working fine again.
Old Jul 1, 2022 | 08:03 PM
fpt2's Avatar
fpt2
Double post
Old Jul 1, 2022 | 08:18 PM
Mike1's Avatar
Mike1
Glad it worked out for you.
PSDNovice
Aug 23, 2021 02:25 PM
Fuzzpuss
Jul 23, 2021 05:04 PM
preppypyro
1997 - 2003 F150
Feb 26, 2018 09:17 AM
T.9.X
Apr 12, 2011 07:27 PM
IM1096
Nov 6, 2007 04:55 PM
