Transmission codes
Old Jul 22, 2021 | 09:16 PM
Fuzzpuss's Avatar
Fuzzpuss
Transmission codes
I am considering buying an 2003 F250 that has the following transmission codes:
P2701 Transmission Friction Element "B" Apply Time Range/Performance
P0715 Turbine/Input Shaft Speed Sensor "A" Circuit
P0730 Gear Ratio Error
The only noticeable performance issue is the 2-3 shift. It hangs in 2nd gear way too long and then slams into 3rd. This is significantly more pronounced when the transmission is cold. Not sure if this also matters, but the O/D button on the shifter is broken off, and the O/D light is not illuminated.
Hopefully this is all symptomatic of something easy like a solenoid or harness, but my knowledge of transmissions is lacking.
Old Jul 22, 2021 | 09:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think the root cause is the turbine speed sensor circuit issue. I'll bet if that is fixed the other problems will go away.
It could be the turbine speed sensor, but it is most likely the wiring between that sensor and the PCM.
Old Jul 22, 2021 | 10:35 PM
IHateCommieCars's Avatar
IHateCommieCars
Just a thought - if it is the sensor, and that sensor is the one on the top of the transmission, it's easy to replace through the doghouse on our Eseries, but I'm wondering if Chris would have to drop the crossmember and lower the trans to get it out of an Fseries. Mark is almost always right, and it's logical that it's a wiring issue causing all of it. None of the tranny harnesses are expensive or difficult to install. Doesn't sound like a deal breaker to me.
Chris, if you like it, maybe negotiate a trans fluid change in the deal, and check that for metal before you hand over your money.
Old Jul 23, 2021 | 10:33 AM
Fuzzpuss's Avatar
Fuzzpuss
Thanks Mark! I was hoping you would chime in.
Even if it is just a harness issue, what damage could have been done if its been going on for a long time?
Old Jul 23, 2021 | 05:04 PM
Mark Kovalsky
Maybe nothing. It's really hard to tell without a teardown.
Wesley Redondo
Modular V8 (4.6L, 5.4L)
Jan 26, 2017 01:38 PM
desertt5
Sep 27, 2010 10:17 PM
Fasterthangator
Mar 19, 2010 03:00 PM
landcruzr
Dec 23, 2009 06:35 PM
