Having a lot of hestiation when coming to a stop and going through 1st and 2nd gears, blinking O/D light, etc. Everything seems fine once I'm at 20mph or so. Scanned with Forscan and the codes it gives are P0503, P0720, P0722. I've changed out the input and output sensors in the transmission as well as completely replaced the wiring harness (from the engine bay all the way back to the rear output sensor). Anyone have an idea on what to check/change out next?
