Sputtering problem (Solved)
Old Jun 11, 2022 | 08:35 AM
z31freakify's Avatar
z31freakify
Test drove truck yesterday after installing my reman injectors and I have a sputtering and misfire problem at WOT between 2500- and what ever the rev limiter is.
ICP @idle 540-570
IPR @idle 9-10%
ICP @WOT @3k+ 2800
IPR @ WOT @3k+ 30-36%
The problem when this sputter happens the ICP spikes up to 3200psi and IPR IIRC drops or stays at 30% and truck has a misfire on at least one cylinder (truck vibrates when it happens) and it randomly does it as well. (So me thinks it's a sensor or wiring problem, which is weird as truck ran good before injectors and before one of them crapped out and even them it only misfired at idle wot ran great)
Have codes for open circuit on bank 2 accompanied by injector open circuit on injectors 2,4,6,8 when I did a buzz test.
Checked resistance on wiring to and from IDM, VC harness and even swapped 2 idms with the same result.
Any thoughts on what could it be?
(after going back and checking every single wire going to the engine harnes and finding nothing wrong. I decided to unplug the battery to reset any codes that my scanner "missed"
and this is where I realize I never unplugged the freaking battery's when doing the injectors, oops, although not the first time I have forgotten to unplug them but never had something like this happen so there's that.)
Behold! problem went away bank 2 codes dissappear when doing the buzz test, truck runs awesome, no more sputtering put 50 miles on it and is doing great.)
Old Jun 11, 2022 | 08:38 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You mentioned you checked resistance from IDM to VC harness, does that include the UVCH down to the injector connector? I believe you installed "updated" Dorman UVCH's on the same truck, is that right?
Perhaps the issue with the wiring only presents itself when a certain vibration (RPM or engine load) is attained?
I can post the pinpoint tests for the DTC's you have, but I am pretty sure you are already familiar with them.
Old Jun 11, 2022 | 08:44 AM
RacinJasonWV's Avatar
RacinJasonWV
My mind went to the new gaskets as well.
Losing a bank or injector would drive ICP up and IPR would try to compensate according to the logic in my head.
Quickest check may be to throw the old gasket back on there.
Old Jun 11, 2022 | 08:51 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Give it 100 miles of spirited driving.
Old Jun 11, 2022 | 08:57 AM
z31freakify
Originally Posted by Sous
You mentioned you checked resistance from IDM to VC harness, does that include the UVCH down to the injector connector? Yes. I believe you installed "updated" Dorman UVCH's on the same truck, is that right? Yes
Perhaps the issue with the wiring only presents itself when a certain vibration (RPM or engine load) is attained? That's my thought as well
Si.
Going to try that next
Plenty of Rat Flink driving. I'm thinking wiring as it only does it randomly.
I'll change the driver side gasket and go from there even though it tested "good".
Old Jun 11, 2022 | 10:15 AM
Old and soft's Avatar
Old and soft
No more dorman for me. These dorman harnesses were installed by a shop 1000 miles away from home on a trip to CO. These pics are of a harness less than 2 years, and under 5000 miles. The insulation is cracked/split.
Old Jun 11, 2022 | 08:44 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Check under 42 pin harness too.
So the buzz test is consistently bad on bank 2?
Old Jun 12, 2022 | 07:45 AM
z31freakify
Yes, buzz on all injectors sound nice and loud. I don't know why it keeps popping up when I do a buzz test. 42 pin connector insulation is good, and away from the valve cover, and resistance check proves its not shorting out.
I'm starting early, couldnt check yesterday way hot.
Old Jun 12, 2022 | 11:50 AM
uglypitbull's Avatar
uglypitbull
ICP @idle 540-570
IPR @idle 9-10%
ICP @WOT @3k+ 2800
I had a similar issue when I swapped my CPS from the gray to the dark blue version......mine sputtered as soon as I hit the pedal though. I swapped back and it went back to normal.
I hadn't thought to check my ICP/IPR numbers though.
Old Jun 12, 2022 | 12:08 PM
z31freakify
Ok new development.
UVC changed same outcome.
But noticed that when I turn the AC the rpm drops to the point of making the engine stall, at idle with AC on the idle surges from 500 rpm up to 750rpm.
As soon as I remove the ICP it don't do it no more, checking wiring to the ICP (ICP is not that old and sawpped in a known good one)
Numbers look the same when this happens .
Old Jun 12, 2022 | 10:24 PM
z31freakify
Solved! Apparently for what ever reason reseting the PCM with my scanner didn't do the trick, but unplugging the battery's did. Truck is running awesome.
Old Jun 13, 2022 | 08:10 AM
Sous's Avatar
Sous
FTE Emeritus
Everyone knows electrical gremlins are unforgiving and relentless. Good to hear you figured it out and can now go on to enjoy the new parts.
Stay cool over there sir!
Old Jun 13, 2022 | 09:09 AM
RacinJasonWV
Great news, nice work!
Mikethezipper
Apr 15, 2022 06:39 PM
Jay Fletcher
Apr 7, 2013 10:33 AM
dieselsubmariner
29
Nov 29, 2012 07:24 AM
bobert64
Mar 27, 2007 11:14 PM
BadFord99
Aug 12, 2006 09:41 PM
