Trouble on a trip….
Old Jun 17, 2022 | 06:59 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I would say that most of us would agree with the course of action Leonard has laid out for you to pursue.
Also, below is a good link on the details of "back probing" if you are interested.
Link: https://www.ford-trucks.com/forums/1...l#post19365825
Old Jun 17, 2022 | 09:29 AM
Kwikkordead's Avatar
Kwikkordead
Given the age of these vehicles now, wouldn't it be easier, and a more thorough repair to just replace the wiring harness and be done with it instead of all this back-probing, then trying to unravel and repair? I bought a wiring harness ten years ago as a hedge against a day like this for myself.
Old Jun 17, 2022 | 10:29 AM
helifixer's Avatar
helifixer
was the injector you replaced in November on the driver side?
if yes I would guess a pinched or chaffed wire under the valve cover.
also unplug the fuel bowl heater.
Old Jun 17, 2022 | 02:42 PM
Capt'n Jack's Avatar
Capt'n Jack
The bowl heater hasn’t been plugged in for years.
Last year I only replaced the injector solenoid on #6, not the injector. Its interesting to me that with all the codes, 6 isn’t having any issues. 2, 4, & 8 have codes.
Tomorrow I’ll have some time to tear into it and see if there’s anything obvious in the valve cover.
Old Jun 19, 2022 | 08:02 PM
Capt'n Jack
Based on all the codes, I decided to start with a new injector solenoid on #8. That seemed to eliminate the worst of my issues, but it would still occasionally shut off on its own, just like I turned the key off. With the number of codes relating to harness issues, I decided to just change the valve cover gasket since I had a new one on the shelf. Just for kicks I also figured I’d change the CPS out for another new one.
Problem solved. 200 mile/4 hour test drive without a single hiccup. Not exactly sure which part was the culprit, but it’s running great, so I don’t really care at this point.
Old Jun 19, 2022 | 09:01 PM
Sous's Avatar
Sous
FTE Emeritus
Most likely the contacts in the gasket between the UVCH and the engine harness were faulty or loose. As you mentioned, no matter now.
Good news on the easy fix action and thanks for closing the loop.
phinner
93
Apr 20, 2013 06:41 PM
No_BS
15
Mar 21, 2012 06:29 PM
preppypyro
15
Aug 22, 2009 07:19 PM
884x4broncoII
Mar 31, 2009 09:55 AM
savage250
Jul 7, 2007 07:41 AM
