Trouble on a trip….
As usual for me, the only time I seem to have problems is when I forget to bring FORScan with me. I swapped around a few relays, mainly the IDM but the issue is still there.
I’m still leaning towards the CPS being the problem. The spare I had in the glove box was new, but it’s a black one. Any suggestions would be greatly appreciated.
You have a 2002, so the RPM gauge will not move if the CPS has failed or is working properly.
You are confident about nailing the issue down to a fuel delivery problem as you mentioned. Have you checked the positive and negative connections on the fuel pump under the driver seat? I believe the relay for the fuel pump is behind the stereo and it has been known to have problems, not a lot of times, but sometimes.
You had an injector solenoid fail recently, does it seem like that sort of failure except it dies instead of running rough?
Check the areas the fellas mentioned and come back to us.
Lastly, start traveling with FORScan Lite on your phone or tablet. If you have an OBDLink MX or MX+, you can leave it plugged in all the time as it goes to sleep.
No chip, so at least I know that’s not the issue.
This doesn’t feel at all like the Injector solenoid problem either.
I thought about loss of power at the fuel pump, but I feel like an instant loss and return of power there wouldn’t even be noticed the way this is noticing.
As this is doing its thing, I am getting a bunch of clicking in the relays in the fuse panel under the steering wheel. Some of those relays are very hot to the touch, that doesn’t seem quite right either. I had overdrive turned off and noticed the OFF light flickering along with the relays. That leads me to think I’m dealing with a bad ground somewhere.
I’ll check on the other suggestions this morning and report back.
Sous, I know I should never leave the house without FORScan, and on trips I haven’t since the injector problem, until this time. Seems like if I bring it along, I’ll never have an issue! I’m planning on an iPad mod to the dash that’ll give me the option of having FORScan with me all the time. When I bought it, I didn’t know enough to get the Bluetooth dongle instead of the PC adapter cord, so that’s what I’m using for now.
Since you have a 2002, I am not sure if you have the fuseable links under the air box featured in this recent thread. Check there too!
Link: High current junction box wire brake
Keep us updated sir!
First hundred miles I could go for a while, then the bronco bucking would start. I held my finger on the relays under the dash and isolated the clicking to the IDM relay. It would buck, spit & spotter for a few seconds, then return to normal. Zero consistency to the issue. It just does it whenever it wants.
The second hundred miles I ran with the ICP unplugged. The problem improved by about 90%. I can still feel some hiccups, but it doesn’t lead to the relays clicking and the bucking bronco ride.
Based on my experience last November, I’m thinking I have another injector solenoid failing intermittently. That causes the ICP to shut off the IDM relay which then will shut the fuel down for a split second, then the solenoid works again and the IDM turns the fuel back on. This causes the bronco ride. With the ICP unplugged, the solenoid miss fires the injector, but the pressure reading isn’t happening to shut off the IDM relay. Does this make sense anywhere else but in my head?
I'd replace the IDM relay, or at least swap with another nearby. Since it ran better with ICP unplugged I'd get a new ICP on there. OEM Ford there, even if pricey.
I have already ordered a new ICP to try, but being on that not being the problem. With it unplugged, I still get an occasional misfire and hiccup.
I’ll try a few more things and report back in.
2, 4, & 8 all say High to Low Side short.
Injector multiple faults bank 2.
Injector High Side Short To Ground Or Power - Bank 2
Cylinder #8 Injector Circuit Low
CPS circuit failure
I’ll attach pics of all of these. Still runs like garbage with the ICP sensor plugged in, and manageable with it unplugged.
