P1633 KAM
Old Jun 17, 2022 | 09:01 PM
Yahiko's Avatar
Yahiko
To back probe you slide a probe or wire down the back side next to the wire.
You are putting the probe through the seal (7) and make contact with the
pin (1) and that way you don't have to worry about stretching the female contact
or risk shorting the male pin out on some other pin.
Here is a nice little kit on Amazon.
Amazon Amazon
One quick easy thing to try is a can of electronic contact cleaner and spray both sides of the plug
so you sure that they are clean.You can then put some dielectric grease on things to keep moisture out.
Also if you find damage there are repair instructions in the PDF that I posted with this.
Old Jun 21, 2022 | 06:59 PM
Yahiko's Avatar
Yahiko
Just checking on your project.
NotEnoughTrucks2014
1997 - 2003 F150
15
Sep 7, 2021 10:49 AM
1995Bronco351
1978 - 1996 Big Bronco
17
Oct 5, 2015 08:41 PM
Iceman5192
1997 - 2003 F150
Aug 15, 2013 09:54 PM
1995Bronco351
Jan 7, 2011 11:57 AM
77300i6
1983 - 2012 Ranger & B-Series
20
Oct 22, 2008 06:55 PM
