Cooling System Vacuum
Old May 31, 2022 | 05:51 PM
FiveOJester's Avatar
FiveOJester
Yesterday was checking some things on the truck and noticed the coolant hose between the thermostat and radiator was collapsed. Pulled the cap and the cooling system was actually under vacuum. Engine had been sitting all night, fully cooled off. Anyone ever seen this before? I think the cap is just a pressure release, not vacuum release.
I did just replace the radiator last week. I had opened the cap with the engine hot when checking for air and I'm guessing when it cooled the pressure was allowed to go into a vacuum as the coolant will contract when cooled off.
All radiator hoses in system are 6-month old Motorcraft, look in fine shape. Same for the degas bottle & cap. Radiator just got replaced.
I can't think of anything that would pull the system into a vacuum besides the thermal affect so it's probably due to me opening it when hot. Guess I've proved that the system is tight!
Old May 31, 2022 | 09:25 PM
Motohead911's Avatar
Motohead911
Well not an expert, I am pretty sure caps are also suppose to relieve vaccum.
Old May 31, 2022 | 11:16 PM
Hartwig's Avatar
Hartwig
Thats a good sign on the other hand -》 engine builds up no coolant pressure.
Old Jun 21, 2022 | 02:30 PM
FiveOJester
So the system is still pulling the upper hose into a vacuum when it cools down. Also it feels like there isn't any coolant in the hose during this case.
I'm wondering if I've got an air pocket stuck somewhere in the system. Looking at the coolant flow diagrams it appears the only real spot that could hold air is the heads. The outlet to the intake is on the side of the head and not at the very top so I could have a pocket above that.
I've tried running a higher rpm for an extended period (2750rpm for 10 minutes) when I was going up a hill figuring that might push the air out but still happens. And the cold coolant level didn't change so I don't think that did anything. I seem to recall some procedure that uses vacuum to suck the air out of the system?
Need to get my coolant pressure sensor installed & hooked up. I'm wondering if the cap is blowing off at too low of a pressure. It's a 2yr old Motorcraft unit. That would definitely explain it.
Truck has no cooling problems so far. I'm doing my first camper tow of the season this weekend so we'll see how she does.
Old Jun 21, 2022 | 03:28 PM
Motohead911
Get that coolant pressure gauge set up. I would love to compare notes after you install it.
Old Jun 21, 2022 | 06:45 PM
Yahiko's Avatar
Yahiko
Barrow a Radvac and pull a vac I’m on
the system. Then use it to do the filling.
You might also want a new cap.
Old Jun 21, 2022 | 10:18 PM
xcrsp440's Avatar
xcrsp440
I recall having a spring like winding inserted into coolant hoses. It would prevent collapsing.
Old Jun 22, 2022 | 02:04 AM
Yahiko's Avatar
Yahiko
The spring would be in the outlet side of the radiator.
The cold side. That should be the lower hose. I don't
recall if there is a spring in it or not.
Old Jun 22, 2022 | 08:25 AM
TooManyToys.'s Avatar
TooManyToys.
No spring in these hoses.
Old Jun 22, 2022 | 11:35 AM
Yahiko's Avatar
Yahiko
That is what I was thinking. Been a few months sense I had one of the hoses in my hands.
Old Jun 22, 2022 | 11:46 AM
diesel_dan's Avatar
diesel_dan
Hopefully not too long before you'll be handling one again!
On some vehicles the spring on the intake side of the water pump (outlet of radiator) was to prevent the pump from collapsing that hose with suction - that's the reason for them that I recall...
Korya
Nov 1, 2016 09:22 PM
Hartwa
Feb 26, 2014 07:24 PM
Ford97150
1997 - 2003 F150
Nov 23, 2007 06:39 PM
oxwht150
Feb 20, 2007 01:06 AM
packrat56
Aug 6, 2004 08:08 AM
