Sponsored by: Real Truck
Blinking OD Light
Old May 12, 2022 | 06:17 AM
fpt2's Avatar
fpt2
Blinking OD Light
2001 f250 5.4 2wd
My OD light is blinking and check engine light came on (mostly when I come to a stop). P0720 code. I changed the output sensor on transmission, no change. Wiring seemed to look fine. Is there a transmission temp sensor in the 2001 (there is no gauge). Change fluid and filter? Any other ideas?
Old May 12, 2022 | 07:48 AM
WE3ZS's Avatar
WE3ZS
If the OD light is blinking that means the transmission has a trouble code set, that’s separate from the PCM and engine codes and simple code scanners can’t read the trans codes. Forscan can read the trans codes, which should get you the info you need to troubleshoot it.
Old May 12, 2022 | 07:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by fpt2
Any other ideas?
My idea would be to check the wiring.
Saying the wiring looks fine is totally meaningless. The wiring needs to be checked for continuity from the PCM to the sensor, and for shorts to ground and to power.
Old May 12, 2022 | 07:55 AM
projectSHO89's Avatar
projectSHO89
Yes but this isn't a TFT issue and no, changing the fluid and filter won't address the stated fault.
A cursory visual inspection can only reveal gross defects. If none are obvious, you'll need to step up your troubleshooting game.
Use your scan tool to monitor the OSS signal while test driving to see if you can better characterize what the PCM is seeing. It may be noisy, erratic, or reduced amplitude which can cause the PCM to squawk about it. Once you have a better handle on the nature of the fault, you can better figure out how to address it.
Old May 12, 2022 | 09:35 AM
fpt2's Avatar
fpt2
Any recommended place to buy a good scan tool?
Old May 12, 2022 | 09:36 AM
projectSHO89
Usual suggestion is Forscan w/ extended license on a Windows laptop and an OBDII interface.
Old May 30, 2022 | 06:45 AM
fpt2's Avatar
fpt2
I got around to getting Forscan and a connector. Here are the codes it gives. P1000, P0325, P0503, P0720, P0722, B1869, C1145. I notice there is a lot of live data you can get while driving. I went ahead and added a few transmission items and no fault in Shift Solenoid 1 Status, Shift Solenoid 2 Status, Transmission Fluid Temperature Status, or Transmission Range Status.
Old May 30, 2022 | 07:06 AM
projectSHO89
You should probably focus on the OSS codes (P0503, P0720, P0722) first instead of getting distracted by the other stuff. Pull up the PID for the OSS sensor and monitor it while driving (safely). If it's missing or erratic, go back to the previous recommendation to check the integrity of the OSS signal wires between the sensor and the PCM. That will require the use of a meter.
The knock sensor (P0325), airbag (B1869), and ABS (C1145) codes can wait.
Old May 30, 2022 | 09:09 AM
fpt2's Avatar
fpt2
I agree, just not sure where to do from here with tracking down the problem. I figure it's best to start small (wiring, sensors, etc.) before spending money on a new transmission. Anything in Forscan live data that could point me in the right direction?
Old May 30, 2022 | 09:11 AM
Mark Kovalsky
If you do buy a new transmission, you'll find that you have the same problem. Your problem is in the wiring, not the transmission.
Old May 30, 2022 | 11:04 AM
fpt2's Avatar
fpt2
That is what I'm hoping for. I don't see anything visually that stands out on the wires, anywhere specific I should start while testing wiring?
Old May 30, 2022 | 06:45 PM
Mark Kovalsky
Yes, you should electrically check the wiring from the PCM to the OSS.
RÖENTGEEP
Mar 23, 2018 01:49 PM
luvemhot
13
Jul 26, 2013 01:21 PM
F350long
Oct 1, 2007 09:14 AM
RHINOROGER
Jan 8, 2006 07:29 PM
Edman
1983 - 2012 Ranger & B-Series
May 29, 2004 05:24 PM
