Trans Trouble
Old Jan 2, 2006 | 05:33 PM
RHINOROGER's Avatar
RHINOROGER
Question Trans Trouble
I Have 97 Crewcab Psd, I'm Getting Trouble Light Flashing On The Od Light Button And The Check Engine Light. If I Rev The Motor The Light Will Go Out For A Few Moments. If I'm Driving The Light Will Go Out If I'm On The Accelerater. I Just Bought This Truck, It Has 218,000 On It.
I Have Changed The Filter And Fluid, No Changes. Any Help???
Old Jan 2, 2006 | 06:04 PM
stroker2's Avatar
stroker2
The OD light flashing means a DTC (diagnostic trouble code) is being set into memory. You need to have the codes read to determine where the problem is. Many auto parts places have code readers and will read the codes for free. A dealership will also do it but might charge you a diagnostic fee, about $70-75 from what I've read.
Old Jan 3, 2006 | 12:20 AM
RHINOROGER's Avatar
RHINOROGER
Code Readers???
So What Is A Good Code Reader?? I'm Sure There Are Lots Of Preferences But What Is The Best Or The Least I Should Be Looking For In This Tool?
Old Jan 3, 2006 | 09:55 AM
1997F-350's Avatar
1997F-350
you want either one of the following
obd2.com "ease" or
autoengenuity
Old Jan 8, 2006 | 07:29 PM
Seatow's Avatar
Seatow
Where is the port to plug in the reader on a 94.5?
