My truck sputtered out died won’t start, cranks has smoke coughs on the starter, new ipr cps Icp good battery’s has smoke fuel in the bowl passes buzz test no codes need help
How much fuel in the tank? Does your scan device live stream engine pid's? Fuel pressure test may help also. There's a simple method in the tech section that uses the fuel bowl drain as a temporary test port. Need about 40# for proper injection.
Fuel pressure good
cps good
ipr good
icp good
good cranking speed
good batteries
passes buzz test one injector has low to high side open
exhaust back pressure valve solenoid looking thing on the turbo is rotted and has a code
barley any smoke from the tail pipe
i will have to check under valve cover harness tomorrow for burned pins
Fuel pressure good
cps good
ipr good
icp good
good cranking speed
good batteries
It would help us diagnose if you provided numbers or readings for all the "good" things.
And the actual code.
The mystery injector that had the high to low open, how did it sound on the buzz test?
