Hard shifting
Old Apr 16, 2022 | 10:23 AM
Codybevan's Avatar
Codybevan
Hard shifting
Hey guys, I’m new to the group. I have a 2012 f250 6.7 with Ezlink set up. Every now and again I will get code U0101 lost comms with TCM. I notice when this happens the truck will shift hard and irregular shifting until I reinstall the stock tune then it’s good for a while. Anyone have this issue. It’s at the transmission shop and they are telling me the torque converter is bad but they haven’t dropped the pan yet and it’s not throwing any other codes.
Old Apr 16, 2022 | 02:14 PM
kper05's Avatar
kper05
I don't have answers but will ask for information that'll maybe help others respond.
What is the battery voltage at idle?
How long have you been using this aftermarket calibration on the TCM before the loss of comm DTC issues began, has it always had this sporadic issue or was fine for X number of years/miles?
To confirm, when you flash with the stock calibration, this U DTC still occurs eventually?
I don't see how a failing TC will cause a U DTC, however I could believe a TCM issue, either the module itself failing, wiring or a bad calibration, causing hardware to eventually fail.
Hopefully the shop knows how to diag electronics and wiring before replacing the TCM as a guess.
Old Apr 18, 2022 | 05:35 AM
senix's Avatar
senix
If you return to stock for awhile and no issues then it is your calibration on the EZ link.
JRW22197
Apr 30, 2020 08:13 AM
48f1builder
Apr 1, 2016 10:41 PM
CanadianSmokie
Nov 23, 2009 04:56 PM
ssquints999
Feb 1, 2009 07:30 PM
Fuelinjector06
18
Apr 28, 2004 08:06 PM
