Hi all, My 94 F-150 4x4 5.8 auto, intermittently shifts very hard, it snaps your head back, other times it shifts perfectly. Anyone else have this problem? Thanks, Al
Code 62 is excessive converter clutch slippage, from what I have seen on here that most likely means you need to replace the torque converter, that code would certainly put the PCM into protect mode which is what produces the harsh shifts.
