steering column bearings
Old Apr 8, 2022 | 07:48 AM
peter sipp's Avatar
peter sipp
My lowest brg, just above the rag joint has died. I tried some plastic ones from LMC...lasted 3-4 weeks. There was a post by someone who made the two that are under the hood...I think. Would anyone have any experience with this situation, know the steering column size and the tube ID they fit into? My truck is a '65 F100 2WD. Thanks in advance, Pete
Old Apr 8, 2022 | 08:13 AM
James_Western_Canada's Avatar
If you search, you should find multiple posts that have the OEM part number for these. They may still be available from Ford dealers, if not, try running the PN on rearcounter.com
HTH
James
Old Apr 8, 2022 | 08:46 AM
Red60's Avatar
Red60
Is there a reason for the failures? The LMC part quick fail makes one wonder why. Might be an underlying problem to address before sacrificing more parts.
Old Apr 8, 2022 | 04:28 PM
peter sipp's Avatar
peter sipp
Hi James,
My D. Carpenter book doesna show any part # for a '65 :-(, So I'm kinda stuck. I'll look at oem. See what I can find out...Thank you James!!
Old Apr 8, 2022 | 04:37 PM
peter sipp's Avatar
peter sipp
Hi Red60. Yes, you are on it. I actually had a shop replace the two brgs. I suspect the shaft is narrow where the original one was. That is a welding solution if that's what caused the LMC plastic brg to fail. Am looking for another steering column. Not too many around. Flashback 100's, Tom (the owner/operator) recently left us. He was in east NC...I'm in west NC. Thank you for responding. All the best to you.
Old Apr 8, 2022 | 04:43 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Here may be the thread you are thinking about. 1965GTFB replaced the OEM with a sealed bearing.
Blue Top Steering Box Rebuild/Install and Column Lower Support Bearing Install - Ford Truck Enthusiasts Forums (ford-trucks.com)
You can also get the OEM style bearing either NOS or reproduction.
c3dz-3517-a: Search Result | eBay
Some of those come with the plastic sleeve a.k.a. bushing.
b1az-3518-a: Search Result | eBay
If these parts are falling apart or getting destroyed in just a few weeks then you may have cab mount sag or possibly the column is under a bind for some other reason. Even a sealed bearing could fail if that's the case. Just sayin' it may be worth a look.
Old Apr 9, 2022 | 05:50 AM
peter sipp's Avatar
peter sipp
Hi TA455HO,
The brg right under the steering wheel sounded like there was gravel in it. The truck was 17 yr old when I bought it. So that makes 57 yrs of service...is this average?
9 yr ago I made a cab support for the drivers side. The pass side is needing to be done too now. So, you are right about the steering column being in a bind. I did not consider the sagging on the pass side to cause trouble. Thank you for your giving your thoughts on this situation.
All the best, Pete
Old Apr 9, 2022 | 06:14 AM
peter sipp's Avatar
peter sipp
Hello again...yes you found the story about the made up brg. Thank you !! That is one sturdy brg. I'll make another cab support for the pass side. Weather permitting, light snow last night :-( . All the best, Pete :-)
Rick 1966
Apr 6, 2020 08:32 AM
johnmel59
Apr 2, 2014 10:48 AM
The blue oval
Nov 6, 2013 12:55 PM
79GreenMonster
Nov 23, 2004 09:19 AM
