Steering column bearings?
Old Nov 23, 2004 | 01:41 AM
79GreenMonster's Avatar
79GreenMonster
79 F100 4x4 - what would cause the steering to bind and then loosen up? Checked the steering box, rag joint, & u-joint - they're all good. Are there bearings in the steering column? That's the only thing I can guess at this point.
If there are bearings, what's the process for replacing them?
Old Nov 23, 2004 | 01:45 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
try dripping a little oil over that steering knuckle(u-Joint) and turn the wheel back and forth to work it loose
Old Nov 23, 2004 | 04:51 AM
Torque1st's Avatar
Torque1st
Posting Legend
I had a column with a bad upper bearing that did that. You can get good assy drawings and instructions in the OEM service manuals on CD from the online store here.
Old Nov 23, 2004 | 05:25 AM
ranger429's Avatar
ranger429
On the end of the column there is a bearing encased in a white plastic sleeve that fit's into the column tube for the steering shaft.
Old Nov 23, 2004 | 08:51 AM
KJKozak2's Avatar
KJKozak2
To check if it's the bearings, disconnect the shaft that goes from the column to the pump and spin the wheel. I doubt it's the column bearings though. My guess would be the rag joint. Even though it looks ok, it could still be stretched out. Mine was like that and did the same thing you describe. Every now and then that little post would misallign with the groove and bind up. It was hard to actually see it happen. I had to wait for it to bind and have someone pop the hood and take a look.
Just a thought.
Kevin K.
Old Nov 23, 2004 | 09:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
Bad cab mounts can cause binding also.
