Steering wheel alignment - wheel vs rag joint?
Old Apr 3, 2022 | 04:50 PM
Its_Green's Avatar
Its_Green
Steering wheel's been off kilter since I got the truck so that's one of the next things to tackle. This is the setup where nothing in the linkage is adjustable. I originally was going to pop off the wheel and center it, but it looks like someone replaced the rag joint in the recent past and it's possible they got it out of alignment on the shaft or box. Is the rag joint spline keyed or can you rotate it? Any point to centering the steering wheel using the rag joint vs the wheel? Can you tell which one is centered to factory spec on the shaft?
Old Apr 3, 2022 | 06:11 PM
tbear853's Avatar
tbear853
Steer to one side to lock, then carefully and slowly turn to the other lock counting full turns and any half turns. Center for the steering box is half way between them.
Old Apr 3, 2022 | 06:22 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on make sure the box is centered via tbear's directions. And then either pop off the steering wheel (steering wheel puller) and recenter. It should be 100% all splines and that is the easiest way.
Yes the bottom part of the rag joint mount (round plate) is splined on to the steering box input shaft. But it can be a PITA to get it off, as in remove the nut and the thru bolt, then pull the column out a bit, and then get it to come off ect...
Pop the steering wheel (with a puller) which is a borrowable or rentable item from most parts houses.
Old Apr 3, 2022 | 06:27 PM
Its_Green's Avatar
Its_Green
Thanks. Yeah, I'm familiar with the process but I'm trying to figure out how many places someone could have reassembled it off center. So the splines in the rag joint aren't keyed in any way? Does the steering shaft itself care about its own orientation or can it be any way 'round as long as the steering wheel is put on straight?
Old Apr 3, 2022 | 07:07 PM
85e150's Avatar
85e150
Usually it's because whoever did the alignment and toe adjustments didn't center the steering.
How far off is the steering wheel? I had a couple instances where the "alignment" person left the steering wheel 1/4 turn off.
Old Apr 3, 2022 | 07:49 PM
77&79F250's Avatar
77&79F250
No the steering column center shaft splines (on ether end) are not keyed or have a flat tab area. And no the steering box input shaft is not keyed either. Yes if you replace the rag joint and let things spin around that can get things off center. Same for the rag joint to steering box input shaft.
Old Apr 3, 2022 | 07:58 PM
tbear853's Avatar
tbear853
For well over 20 years my stock steering wheel was turned about 10 degrees to the right to go straight, but after testing for its center, I knew it was just rooted in the position of the steering wheel on the steering shaft, maybe 3 splines worth, ... but I chose to "leave it be" as it was just so darn comfortable to drive with that left arm on the arm rest ... resting. I corrected it a few years ago when I went the Red Head way.
Old Apr 3, 2022 | 11:03 PM
tbear853's Avatar
tbear853
I just forgot this question earlier, "my bad".
Originally Posted by Its_Green
... etc ... Does the steering shaft itself care about its own orientation or can it be any way 'round as long as the steering wheel is put on straight?
No, the steering shaft doesn't care, but once it's connected to the input shaft of the steering box at the rag joint it is then and extension of that input shaft, and the steering box has limits that limit its travel.
Old Apr 4, 2022 | 07:46 AM
fordrealdrive's Avatar
fordrealdrive
Deleted...
Old Apr 4, 2022 | 12:39 PM
Its_Green's Avatar
Its_Green
Cool, thanks. I'll be digging into it soon.
Tinbird83
Jul 10, 2014 11:45 AM
benbuilder
Oct 26, 2013 04:31 PM
4x4Man09
Dec 3, 2009 10:38 AM
oem78
May 4, 2005 11:25 AM
MikeGV
Jan 20, 2005 06:10 AM
